ADC0838 object problems
I am using the TLV0838, its the same chip primarily. The only difference is it runs on 3.3V instead of 5V. I'm looking at the pulses on the outputs and they all look correct with the exception of their being a slight pause between the clock pulses from end DI and begin DO. All the output pins from the prop - Chip select, Clock and DI are doing what I would expect them to but on the DO pin All I see is a really small signal, its the clock pulse bleeding through at like 10mV and nothing else.
Any suggestions on this?
