Triggering
I was wondering if someone could help me figure what I am doing wrong with triggering.
I have CH2 connected to +5 volts and the ground clip connected to ground. When I am running in non-trigger mode I can see a plus +5 red line and when I remove the channel 2 from +5 and ground it I see the red line dip to 0 volts. Works great.
When I try I step trigger mode nothing works. I have mode=step, edge = fall, level = auto (I also tried 4.8 and 1 volt by dragging the yellow cursor), source = ch2.
The 'click to run' button next to step does nothing.
While in step (or continuous) mode, i simply repeat the grounding expecting to activate a trigger.
Am I missing something?
Thanks all
Thanks all
Noob here.
Jim
I think you might be looking for a serial protocol analyzer. The Propscope does not have that ability right now. I believe the programmer for the product is heading in that direction for new software updates.
Here is a good read on Asynchronous Serial Communication for the Propscope:
http://forums.parallax.com/showthread.php?t=124645
Jim
Hopefully Hanno is working on this along with I2C decoding.
Jim
