How does the Prop solve this timing problem?
John Kauffman
One theoretical question has stuck in my mind since I first saw the schematic of the Prop architecture. In a case where small amounts of time are crucial, what if the hub is pointing to cog 4 and at that very moment, cog0 needs to change a pin? It can't change the pin until the hub comes around to cog0 and by that time it might be too late for timing in Cog0's program.
I can think of two possible solutions that might have been used.
Solution 1 - When cog4 starts and has a pin assignment then that pin is not available to other cogs and cog4 can change the outa[] on its pin regardless of where the hub is currently pointing. In terms of outa[], cogs are independent of the hub.
Solution 2 - The hub 'spins' so fast that it gets from cog to cog quick enough to keep within tolerances of timing for even the fastest and most time-sensitive applications.
Can someone explain how the Prop solves the problem? Thanks.
So if two cogs try to change the same pin:
- programmer's responsibility to not commit that error?
- prop locks pins into a given cog control?
2) I/O access has no timing restrictions. There's a block diagram that shows how the I/O pins are connected to each cog and each cog has its own set of I/O registers. These are OR'd together and any cog can change an I/O pin by changing the cog's I/O registers at any time. If any cog sets its DIR register bit to 1, that I/O pin is treated as an output. If any cog whose DIR register bit is 1, sets the corresponding OUT bit to 1, that I/O pin is set high, otherwise it's set low. This is accomplished with the OR gate chain shown in the block diagram.
8 to 23 cycles now. See http://forums.parallax.com/showthread.php?t=125451
