I need small drill bits. Where can i find them?
Ravenkallen
Well, i have officially looked around(Wal-Mart, Target, Radio Shack) and i can not find anything smaller than 1/16Th. what is the common drill bit size for making dip size holes in your board? Is such a thing available in common stores?
The one near my house has bits as small as .007" !!!
BTW, for DIPs use a .035" drill; for square-pin headers, 0.042".
http://www.megauk.com/
They have distributors in the USA.
Close your drill down to as tight as it gets and see how big the remaining "hole" is. As Phil said, some drills can't grip something as small as 1/16 inch. But don't panic. Almost any drill can handle 1/8 inch shanks, the kind of which Phil pointed you to in McMaster-Carr.
If this is intended for the pcb you are designing, don't drill them yourself! expressPCB can make decent size holes on the pcb. Just click on a hole and then scroll through the selection to get what you feel comfortable with. A hole that fits 4-40 or 6-32 screws should be strong enough to secure that little pcb you showed us earlier. Just space three or four such holes around near the edges of your pcb and you're set. Just make sure you have plenty of clearance around the hole for the heads of the screws so you don't short out ground planes, etc. if you happen to have those on the board.
http://www.rockler.com/product.cfm?page=20388&utm_source=amazon&utm_medium=ad&utm_campaign=amazon
here's a larger one;
http://www.amazon.com/Keyless-Chuck-Shank-Micro-Drill/dp/B001UPTDSY/ref=sr_1_14?s=gateway&ie=UTF8&qid=1285819944&sr=8-14
@Everyone else....I gotta admit that i am not to familiar with drills and the necessary hardware. Perhaps i will find a tutorial online...I might upload a picture of the drill and bits if it would help
Make sure what you're drilling is clamped down. Don't try to hold down the pcb with your hand. Thin workpieces (like sheet metal, etc. ) have this pesky habit of wanting to ride up the drillbit like it's a spiral staircase. I would also like to echo Phil's comment about breaking off tiny drillbits: having some kind of drill press or other guide might be necessary with tiny drillbits as any bending motions tend to snap them off or just bend them toward uselessness. Wear eye protection, too, because those flying broken bits hurt when they stick into your corneas. Finally, be careful how and where you lay down your drill if you've still got the drillbit in it - those tiny drill bits are kinda like big hypodermic needles, so if you accidently bump into one, you get inoculated with whatever microbes happen to be dancing on its tip.
Have fun!
I've also found small drill bits with 1/8" shanks at Harbor Freight.
I think if I tried doing this with a small variable speed Dremel in a drill press it would have broken the drill because they don't have enough low rpm torque the way a cordless screwdriver would using the above arraignment.
that has the same quality of a regular sized drill presses and costs $75. The 6 MM chuck works with drills down to .0225". Of the two holes I drilled ( 1 MM and .0025") into a 1/16" circuit board it only took a couple seconds for each with the belt ratio set a low speed and the speed control set to about 1/4 speed.
The only problem is Center of chuck to front of column is small only 4.25" inches and the chuck fell off because it wasn't cleaned well enough ( I fixed the problem by thoroughly cleaning it before putting it back on see Installing a Drill Press Chuck at" http://www.machinistblog.com/ ").
I get mine from Travers. They have tiny bits with large shanks for your drill and they pretty cheap.
