external powers supplies and relays
Hello
I'm new around here and also new to the stamp plc. I am working on a project where I am using relays to activate AC componants. Unfortunately I am having difficulty with having the stamp plc actuating the relays. I have an additional 12V 1.2A power supply hooked to Dout V+ and my relay is connected to Dout1. Any thoughts would be greatly appreciated.
+12 to Dout+, 0v to Dout-, one relay connection to Dout1, the other relay connection to Dout-. See the plc manual.
Is your program able to turn on an output?
I couldn't produce enough current to drive the relays, so I switched to solid state relays and everything works. Thank you Stamptrol for the input/help
