TTL vs RS232
If I want to communicate with the prop using serial communication (fullduplexserialplus) without going through pins 31/30, do I need to build the circuit which converts ttl to rs232? This is assuming that I am communicating with a terminal program via a 9 pin serial port on my laptop.
That makes sense I don't think mine will, my laptop will read and display the nmea strings in ht with no problem but if I send the exact same data from the prop...... No dice.
I have to ask, what is "THIS."?
In recent months I've seen many posts on another forum that start with a that single word sentence, although not all in upper case. Now I see it here. I can't work out what it is supposed to mean.
Is it just a mistake? Or is it YABA?
This. How bizarre. Soon I won't even understand my native language:)
now to master float math.......
