Most common connectors that anyone would have.
Oldbitcollector (Jeff)
Some "real life" issues have been zapping my Propeller time as of late,
but I'm pleased to be able to have some time to work on projects again!
Question:
I'm putting together some "weekend" type projects for the blog which incorporate the use of a Propeller protoboard and some common controllers.
My plan is to have the project replace the various strange controller connectors with something much more standard that folks may have at home, or so common that a walmart (yes I said walmart) would have. In other words, VERY common.
At most it'll be a four-pin connection to the Propeller.
What types of quick and dirty connection systems have you used? My mind is reeling in what type of male/female connectors might be common to the typical junk drawer. Even brilliant rigs would be interesting.
Yes, I'm going back to my junkbox roots with this project.
OBC
Question:
OBC
Thanks mods!
John Abshier
You might want to check out Pro-Advantage to see if they have your connector:
http://www.proto-advantage.com/store/index.php
Where I live, there are more RadioShack stores than Walmart stores.
They have;
D-Sub connectors
Interlocking connectors
Modular connectors
A/V connectors
DC power connectors
and other connectors.
But the most common connector is the good old DB-9
If you insist on household stuff, modular phone jacks are nice, as you can get pre-made cables.
I'm not sure what you're after here, but I've found that using an inappropriate connector is probably one of the best ways to increase frustration, either from bad connections, or broken wires.
John R.
If you think "Home Depot" instead of "Walmart" you're a little better off, because they will have phone and cable TV stuff including both wire terminations and receptacles. For 4 wires your choice is RJ11 modular phone hardware. There really isn't anything else. Just be sure you don't plug your prop into a real phone outlet that might blast it with 100 volts of AC ring voltagee, the prop might not like that.
Might I suggest this: reference connectors that parallax sells at its site (for convenience in case the builder buys their protoboards from parallax) but provide alternative sources for these (mouser, all electronics, jameco, digikey, etc) should the builder be savvy enough to shop other sources.
I believe the premise is along the lines of "OK, I got the proto/demo board, and I've played around some, now I want to do something neat, on the spur of the moment. I want to run out to my local WalMart [RadioShack] and grab some stuff and make LEDs from an old pair of shoes flash (or something like that).
John R.
Sorry, I'm being a little vague on my requirements, but the idea here is to accomplish amazing things with a Propeller using only items that are common to most households. (Love the Home Depot recommendation!)
I've had some time to process the last demonstration at UPENE in which robots are being built using simple parts which are around the house. I'm looking at a Cookbook update (last one was 2007!) which will incorporate more ideas like this. In other words what could a home user do with a simple USB protoboard, a cheap soldering gun and various items which are common either re-purposed, junk drawer, or easily obtained at common discount stores.
Frequent readers of this forum (myself included) have well stocked shops with connectors, wires, resistors, all forms of sockets, etc. Typical newbies won't have these resources. I'm keen to see what can be done with little at all. Paperclip challenge anyone?
I've got a contest I'm going to kick off which incorporates these ideas. Everyone got a "Dollar" type store around them?
OBC
No, not "A" Dollar store.... about 50 of em'
I'd vote DB-9.... I use them pretty much by default, unless I need more pins, then I go DB-25. Both ends of either are at radio shack. Soldering required of course.
There are cheaper and simpler single and double row parallel pin connectors, but I've had their pins fall out while trying to solder them, and have plugged them in backwards too many times, and have plugged them in offset by a pin or two, and have spent time trying to figure out the connector orientation when first wiring them, and had them wiggle loose when they were the sole support of a small device board.
The DB series of connectors have none of these issues.
I have Tilden's intro book on BEAM robotics and of course the Robot Builder's Bonanza, which is now a bit out of date but still golden. Tilden's genius with BEAM is that the very goal of the hobby is designed to focus on cast-off stuff, so that being able to order a thousand bucks worth of parts doesn't put you at a huge advantage over someone who has to scrounge for tossed-out microwave ovens. It's a bit of an arbitrary focus and not of direct interest to me, but it's inspired some clever circuits and mechanical designs so I keep an eye peeled in the BEAMers' direction. Meanwhile, I just spent a thousand bucks of my boss's money ordering parts...
