Enquiry on hb25 programming — Parallax Forums
b0ib0i07b0ib0i07 Posts: 33
edited 2010-09-26 23:30 in BASIC Stamp
I m currently using bs2 to program hb25 to drive a 12v dc motor.
From what i know : pulsout, pin number,duration can signal a motor to move.
I will like to know why do i need to loop this statement and how does the duration affect the movement of the motor. Like 750 is stop.
And how do i set the motor to lets say move 20 degree clockwise?
  • stamptrolstamptrol Posts: 1,731
    edited 2010-09-25 05:13
    The hb25 is designed to operate the motor at various speeds forward or backwards based on a single PULSOUT command.
    To position at 20 degrees clockwise, you'll need to provide some form of feedback so the controller knows whether to move fwd or rev to get to the desired position.
    You don't give much in the way of detail of what your aims are, but a servo may be better suited to your needs.
    Based on the pulse-width of the PULSOUT command a servo WILL move to a particular position and hold there as long as you keep refreshing the PULSOUT command several times a second.
    Cheers,
    edited 2010-09-25 07:28
    I hope that I am not hi jacking this post by asking this question
    I want to ask about this comment about the PULSOUT command several times a second.
    Then would I be able to run a routine using a optic sensor to keep track how far the motor has moved
  • b0ib0i07b0ib0i07 Posts: 33
    edited 2010-09-25 07:55
    stamptrol wrote: »
    Cheers,
    So lets say : "pulsout, pin14, 850" is use to move e motor 20 degree clockwise. So if i want to hold it in the 20 degree position, do i just simply loop this single command?
    Or can i use "pulsout, pin14, 750" to stop the motor after it reaches that position?
    edited 2010-09-25 12:09
    Again, the hb25 is for controlling motor speed and direction, not position.
    So, your code would make the motor run slowly in one direction until you told it to stop. Without independently measuring position, the Stamp will not know when to tell the hb25 to stop the motor. If you measure the position by some method, as Sam has asked, you have just made a servo.
    On the other hand, those commands fed to a packaged servo would make the servo move to some definite position and stop as long as the signal was repeated a few times a second. When you send "pulsout, pin14, 750" it would return to zero as long as you kept sending that value. The feedback is built into the servo unit.
  • W9GFOW9GFO Posts: 4,010
    edited 2010-09-25 12:48
    b0ib0i07 wrote: »
    For a standard servo you would repeat the PULSOUT 850 command 20 times a second to hold that position.
    If you want the HB-25 to perform like a servo you must add an encoder of some form to whatever it is you are moving. You would command the HB-25 to move in a direction and then monitor that encoder. When the time comes to stop the HB-25 base upon the feedback you have received from the encoder, you would send a PULSOUT 750 command to stop the HB-25.
    Like stamptrol says, a servo may be a better fit for your need. If you were to give more detail about your project we could be more helpful.
    Rich H
    edited 2010-09-25 13:21
    W9GFO wrote: »
    Rich H
    That the most IMPORTANT part of what I need to know
    edited 2010-09-25 23:31
    :smilewinkgrin:thanks all for the help. i will try figure out that.
    edited 2010-09-26 07:56
    Sorry to disturb again.. To double confirm. Hb 25 will move with single pulse command. Means that a "pulsout pin14, 900" command will make the motor keep moving without looping the command or?
    edited 2010-09-26 08:41
    Why not just try it and see? Experimentation breeds familiarity and builds Xperts.
    edited 2010-09-26 10:08
    I tried. It didnt move.
    for index = 0 to 250
    pulsout pin14, 750 + index.
    The above 2 command made it move..
    But i dont understand it o.o
    edited 2010-09-26 10:41
    ' {$stamp bs2}
    ' {$pbasic 2.5}
    for w0 = 750 to 1000
    pulsout 14,w0
    pause 1000
    next
    edited 2010-09-26 17:57
    ' {$stamp bs2}
    ' {$pbasic 2.5}
    pulsout 14,w0
    pause 1000
    next
    *correct me if i am wrong.
    The above program do move the motor. However i noticed that the motor move in increasing speed. Is there any way to move the motor at constant speed?
    edited 2010-09-26 18:17
    You're VERY welcome! Keep up the XLNT work!
    Best,
    edited 2010-09-26 18:24
    You can drive the HB-25 just like a continuous rotation servo. Depending upon which mode the HB-25 is in you may or may not need to refresh the signal to keep it going.
    DO
    Pulsout 14, 800
    Pause 20
    Loop
    Rich H
    edited 2010-09-26 19:10
    Thanks all for the help.
    edited 2010-09-26 19:55
    W9GFO wrote: »
    DO
    Pulsout 14, 800
    Pause 20
    Loop
    Rich H
    The above program didnt move my motor :confused:
    What are the possibilities that cause it to didnt move?
    * I am very sure nothing wrong with the wire connections..*
    edited 2010-09-26 20:04
    Take a look at the two pieces of code and see what is different then play with the code until you can answer your question. That is called learning.
    edited 2010-09-26 20:07
    Are you powering up the Basic Stamp at the same time as the HB-25? Can you power up the HB-25 a few seconds before the Stamp? Or a few seconds after?
    Rich H
    edited 2010-09-26 20:08
    OK:lol:
    I got it.
    think something wrong with the particular port.
    THANKS ALL:smilewinkgrin:
    edited 2010-09-26 20:11
    W9GFO wrote: »
    Rich H
    I did tried.
    But i miss out the pause 20 i think.
    Anw, thanks for the help.
    Btw, starting, my I/O 15 spoiled.
    Now is I/O 7 spoiled.
    Anyone gt any idea whats going on?
    * I just built a particular pulsout program. The program works fine on all I/O ports initially. However port 7 and 15 suddenly stop working.... *
