flexiforce sensor - please help me
Hi
I tried to calibrate the flexiforce sensor (by placing loads on the sensing area and measure the resistace across the terminals using multimeter) but i couldn't get a linear conductance graph although I followed all the steps provided in the user manual http://www.cytron.com.my/datasheet/sens ... Manual.pdf .
Furthermore, it does not gives stable reading when I conditioned/calibrated it. The resistance value kept on decreasing although if I waited for 3 minutes. Besides it also didn't give the same reading although the same amount of weight placed on it.
What should I do? Does this means the sensor has broken/damaged?
I took a look at Parallax's documentation, which I got from the following:
http://www.parallax.com/StoreSearchResults/tabid/768/txtSearch/flexiforce/List/0/SortField/4/ProductID/384/Default.aspx
What first grabs my attention is that this sensor has 5 megaohms of resistance when starting out at zero load. That's an extremely high resistance, so unless you have a special type of ohmmeter that can handle and discern mega-ohm levels of resistance, you are very likely to get weird results with a normal multimeter in the low force range.
Also, you have to be very careful how you apply the force to this type of sensor. Did you happen to see the following?
I'm just going to guess that the sensor is okay but that you have to be more careful how you handle your calibration. Set up your microprocessor (BS2 or whatever) as shown in the Parallax document, then try to calibrate it with that and pay special attention to how you apply your loads.
good luck!
Hope that helps,
Mark
I used one of these by making it part of a voltage divider circuit and hooking it up to an analog to digital converter.
