image sensor
i wanted to use a laser sensor for 3D mapping but they are so expensive. so i look at other options here and i wanted to know what you guys think. im still very new to this but i have plenty of time to do my research. sould i go with the ultrasonic sensor or the image sensor for an autonomous R/C car? i understand you can use both for mapping clear areas for movement but which one could i get a more reliable system from?
also thanks for the help and clarification.
Then, you'll find that they're cheaper to buy at http://www.junun.org/MarkIII/Store.jsp
I bought the line laser but I need a new camera to try it out. If it works like they say, it seems like it would be possible to use a similar setup on a mobile robot (with a nice PC on board) to 3D scan and map the environment around the robot.
But that's a project for another day...
