BS1 Slow Scan Low-Res Camera
Anybody tried it? Tracy, Phil, Mike?
2 servos do a slow point-to-point XY scan of a well-lit scene, aiming a very directional phototransistor & lens system that RCtimes the brightness of each spot. Output could be in many forms, including a course DEBUG screen that recreates the scene onscreen with different characters. Yes, I'm talking low-res, maybe 40 or 60 characters (pixels) wide.
Somebody must have done this using a Stamp. I've heard of a similar setup from the 1980s and the Commodore 64 crowd. Take an analog 2-pot joystick with a similar phototransistor setup, and manually hand-scan a scene, reading X,Y and brightness pixel by pixel, recreating on-screen.
Sure a BS2 or Prop could do it much better & faster. But I'm a simple guy; I like max bang for the buck. I'll proceed if no one has done it yet.
Also, someone else used an optical mouse sensor. I think it was a 16x1 or 16x16 pixel gray sensor. I believe this was done with a computer, but I don't see why it wouldn't apply. You'd need a lens to increase the FOV.
Found it!
http://forums.parallax.com/showthread.php?t=121080&highlight=linescan\
Instead of a pan/tilt for your light sensor, you could also try a Nipkow Disk. It would only require one servo, instead of two. It's what I used with my thermal imager.
