Using the video generator to gerenate frequencies
godzich
Still a rookie concerning the Prop, but learning all the time... A very pleasant learning curve
Can someone sched some light on the video generator that is embedded in each propeller. It is more or less like a blakc box, very little info exists of its inner construction. Or then I'm not good in looking up information...
1. Where to find a document that explains its internal secrets (just little like the AN-001 - for the counters)??
2. Would it be possible to generate a toggling output at some higher frequency - just using the video generator AND without reloading it in software?
I am looking at an application where I already have both counters (A,B) in other use, but need to generate additionally a frequency on an output pin. This is - withing the SAME COG, and without software intervention (waiting for reloading the video register). If the video generator would be built so that the pattern repeats itself then this would be possible - or ?
Cheers,
Christian
Cheers,
Christian
Unfortunately, the video generator uses Counter A as the primary frequency reference (with Counter B as a modulator for broadcast). So if you've already used both counters, the video generator won't give you a third frequency output. Your code will also need to update the generator periodically (via WAITVID).
That being said, the video generator can be used to generate more than video.
