URGENT-Need some help with HB-25 motor controller
I am trying to program a dc motor using the HB-25.
At first, i tried the sample program found on parallax website under the HB-25 product documentation.
The motor move smoothly forward and backwards.
Afterwards, i tried to program PWM.
The motor works fine but after a few tries, the motor would not move.
I re-ran the sample program found in the HB-25 documentation and this time round, the motor would not move either.
*12V dc motor used
*12V dc, 1.5A supplied to the HB-25
May i know what is the fault that had occured?
*12V dc motor used
To help you we need some more details:
- What controller are you using? (BS2, BS2SX, BS2PX, etc)
- How is it wired up?
- You have a 12v motor but how big is it and is a 1.5A supply enough?
- The example code that was originally working.
- The code and procedures you used for trying the PWM mode (whatever that is).
With some more details we may be able to help.
Robert
The solution is to power them on a moment after the microcontroller.
Rich H
Thanks for pointing this out
I have seen this on my Gate Opener that some time when you turn on the power switch some time it will not work
