Problem with MCP42100 ditital potentiometer
Hello everyone,
In the interests of Full Disclosure, I'm a Propeller n00b, but I'm learning fast (I think?) I'm excited about using the Propeller in my current project as well as future ones!
I'm having a bit of trouble with the Microchip MCP42100 digital potentiometer, and the matching Object downloaded from the Object exchange. Specifically, it doesn't seem to be working.
I loaded the test demo in the object folder, and it compiles and uploads properly. I can measure the signals going to the pins on the digitpot with my scope, and they appear fine to me - CS goes low, CLK is... clocking, and there's changing data going in through SI (data in). However, the "wiper" remains fixed in the center (the default value when first turned on).
This data was all collected at 2am last night and I haven't had a chance to fool around with it since then. But, I figured I'd ask here in case anyone has experience with this chip, before I kill by brain trying to figure out what the problem could be.
Thanks for your help!
Rich H
Aslo, as you are measuring the resistance of the pot, you need to measure between the wiper and either A or B. If you measure the resistance between A and B, it will not change.
That's all I can think of right now. The next step I think is to show us how you have it wired up and post the code.
Rich H
I have the CS, CLK and SI pins connected to pins 22, 23 and 24 on the Parallax Propeller USB proto board. I know that data is going into the chip because I can see it flash by on my scope (and probing directly on the pins of the digipot).
Aside from changing the pin assignments, the code is identical to the object I linked to.
I've got two of these parts, maybe I'll try the other one when I get home...
I modified the code so that it would repeatedly write "255" to the digital potentiometer. I did so, so that I could watch it on my scope and see the pattern. It it certainly transmitting what it's supposed to - so why is the digital pot not responding?
Very strange...
Work continues...
Ah well, what's a day of agonizing, eh?
So yeah, the code works fine and I can move on to other things. ADC next? I promise to make sure all the pins are soldered, really!
Rich H
So, I'd measure the pin with my scope and see a signal, but as soon as I'd remove the scope probe the connection would open again.
*sigh* the perils of working sleep-deprived...
