Using Generic Wireless reciver with BS2
Hi guys, i think i posted something about this before but i found this (http://www.robotshop.ca/on-shine-low-cost-tx-rx-4.html) it is a wireless reviver and transmitter for $6.00 and i wondered how i could use it to make a low cost radio controlled bot for the bs2 (with a bs2 controller), it communicates Data via "On-off keyed" (OOK) modulation at 4.8Kbps. I have no idea what that is or how i would use it, could someone help me learn how to transmit and recive these signals? all i really want to do is basically send a foreward, reverse, left and right signals to a bs2 board on the bot.
If you want cheap, you have to deal with doing some investigating for things like pinouts and recommended circuitry. If you want easy, be prepared to pay modestly for the privilege (like buy from Parallax).
SparkFun may carry a similar transmitter / receiver pair and they're good about posting links to datasheets and sample code.
Receiver...
http://www.sparkfun.com/commerce/product_info.php?products_id=8947
transmitter...
http://www.sparkfun.com/commerce/product_info.php?products_id=8945
They are cheap and they work pretty well. Their range is kinda exaggerated though...I did manage to get a signal anywhere in my house which is not to bad...The setup is SO simple. Just add a couple wires, an antenna and a small capacitor(I tried it without and it worked fine). You have to disregard the first couple of bytes sent..
