multidirectional measurement using ping sensor
HI all
I am trying to measure distance using the ping sensor in different directions(one direction at a time,repeititions) at 45 degree from each other, need your advice on the following:
i) will it work? discrete measurement programming code?
ii)single data output from the different directions(eight directions)
iii)advice on addtional components or programming would be much appreciated!
![:confused: :confused:](https://forums.parallax.com/resources/emoji/confused.png)
Mounting sensors like this on top of a servo is pretty common. If I understand correctly, you want to scan a full 360 degrees. Unfortunately, most servos will only rotate through a range of about 180 degrees (RC applications typically limit this to only 90 degrees). You can find servos that will rotate further (typically winch servos for sailboats) or purchase/build gear trains that will allow a full 360 degrees of rotation.
One other approach is to mount two Pings back to back on top of the servo. You will then be able to measure in all 8 directions that you are looking for (and the servo will only need to be moved to 4 locations).
