A CASE of confusion — Parallax Forums
A CASE of confusion
JonnyMacJonnyMac Posts: 9,819
edited 2010-09-20 12:02 in Propeller 1
I decided to toss a last-minute section into my column and am now kicking myself and seriously confused.
What I decided to do is develop a simple implementation of the Renard protocol which is very popular amongst DIY Christmas lighting enthusiasts. The protocol is very simple
sync ($7E)
addr ($8x)
channel levels
$7F is used as an escape character for levels that require two bytes encoding. Easy-peezy. Right.
Well, yes -- and this works with my little 12-channel board:
  repeat
    c := cmd.rx
    if (c == SYNC)
      c := cmd.rx
      if (c == ADDR)
        repeat ch from 0 to CHANNELS-1
          c := cmd.rx
          if (c <> ESC)
            leds.set(ch, c)
          else
            c := cmd.rx
            if (c => $30) and (c =< $32)
              leds.set(ch, $AF-c)
            else
              quit
I thought, however, that a state-machine would be more elegant and be better suited to trap an error in the stream. So I recoded to....
  state := 0
  repeat
    c := cmd.rx
    case state
      0 : if (c == SYNC)
            state := 1
      1 : if (c == ADDR)
            state := 2
            ch := 0
          else
            state := 0
      2 : if (c <> ESC)
            leds.set(ch, c)
            ch += 1
          else
            state := 3
      3 : if (c => $30) and (c =< $32)
            leds.set(ch, $AF-c)
            ch += 1
            state := 2
          else
            state := 0
    if (ch == CHANNELS)
      state := 0
I'm stumped and a tad frustrated because I'm sure it's something ridiculously simple that I'm looking right past. Your input is appreciated
  • JonnyMacJonnyMac Posts: 9,819
    edited 2010-09-20 06:00
    I moved the last channel check from outside the CASE structure to inside and it works now. Seem odd....
    edited 2010-09-20 07:04
    Might it be something to do with "ch" not being initialized until after state 1?
    edited 2010-09-20 07:23
    Compiler bug?
    edited 2010-09-20 07:43
    Mike Green wrote: »
    I thought that might be the case, too, but it's not (what's not shown is that ch is pre-initialized to 0 before the repeat loop).
    This is the dolled-up working version; for now I'm going to live with the redundant channel limit check.
      state := WAIT_SYNC
      chan := 0
      repeat
        rxbyte := cmd.rx
        case state
          WAIT_SYNC : if (rxbyte == SYNC)
                        state := WAIT_ADDR
          WAIT_ADDR : if (rxbyte == ADDR)
                        state := WAIT_LVL1
                        chan := 0
                      else
                        state := 0
          WAIT_LVL1 : if (rxbyte <> ESC)
                        leds.set(chan, rxbyte)
                        if (++chan == CHANNELS)
                          state := WAIT_SYNC
                      else
                        state := WAIT_LVL2
          WAIT_LVL2 : if (rxbyte => $30) and (rxbyte =< $32)
                        leds.set(chan, $AF-rxbyte)
                          state := WAIT_SYNC
                        else
                          state := WAIT_LVL1
                      else
                        state := WAIT_SYNC
    edited 2010-09-20 07:48
    Check your indenting again
    I would be surprised if there were a compiler bug at this late date. I've used state machines like this one including a statement after the end of the CASE statement, but inside the REPEAT and it's worked for me.
    edited 2010-09-20 09:59
    Like you, Mike, I've used this structure before without problems. And, yes, I checked the indenting very carefully (graphic display of indent is enabled) -- even moved the channel limit check to the top of the repeat loop (before rx input) just to make sure.
    I agree that it's probably not a compiler bug, but there does seem to be an unknown (to me, that is). For now I have working code and I'm pressing forward. Thanks for looking.
    edited 2010-09-20 10:58
    Jon,
    I'm not sure about the CASE issue, but I do notice that if you get two SYNCs (or any even number) in a row, starting from WAIT_SYNC, and followed by an address, your interpreter will not do what you probably want it to:
    WAIT_SYNC: SYNC -> WAIT_ADDR
    WAIT_ADDR: SYNC -> WAIT_SYNC
    WAIT_SYNC: ADDR -> [color=red]WAIT_SYNC[/color]
    I think that SYNCs arriving at WAIT_ADDR should not change state, but remain at WAIT_ADDR. In fact, if I understand the protocol correctly, a SYNC arriving at any state should force the next state to WAIT_ADDR.
    Thanks, Phil, that makes perfect sense -- and I thought I had covered that situation (obviously not). Here's where I am at present, which, hopefully, which catch a "broken" stream. It seems to be okay with me "breaking" the connection and then putting it back.
      repeat
        cmd := console.rx
        case state
          W_SYNC : if (cmd == SYNC)
                     state := W_ADDR
          W_ADDR : if (cmd == ADDR)
                     state := W_LVL1
                     chan := 0
                   elseif (cmd <> SYNC)
                     state := W_SYNC
          W_LVL1 : if (cmd <> ESC)
                     leds.set(chan, cmd)
                       state := W_SYNC
                   else
                     state := W_LVL2
          W_LVL2 : if (cmd => $30) and (cmd =< $32)
                     leds.set(chan, $AF-cmd)
                       state := W_SYNC
                     else
                       state := W_LVL1
                   elseif (cmd == SYNC)
                     state := W_ADDR
                   else
                     state := W_SYNC
