Looking for command line loader
Hello, I'm new to the propeller. I discovered it via the HYDRA game development kit which I bought in an electronics store. I am a computer programmer, but I have not done much in the area of microprocessors; so I thought it might be an interesting hobby. So far I am quite pleased with the propeller chip.
However, I am not really a fan of the software. I normally prefer command-line tools for development although I do use Visual Studio some and don't mind that. I use Windows 7. I got Homespun to work for a command-line compiler. (The link was broken in the wiki, but I managed to figure out the correct link then edit the wiki to fix it.) I am now looking for a command-line tool to load the compiled code onto the propeller.
I have found two forum posts that appear to advertise tools that would do this, but I can't find the download links for either tool. Here are the two links:
Can anyone tell me where I can download either of these two tools? Also, if there is a better Windows-compatible command-line compiler or loader, please let me know.
Phil Deets
Edit: In case it matters for compiler suggestions. I am mostly interested in ASM programming. Poor spin support is fine as long as the assembler works well.
- http://forums.parallax.com/showthread.php?t=106449
- http://forums.parallaxinc.com/forums/pr.aspx?f=25&m=161911
Phil Deets
You are probably looking for the "Propellent" command line loader. It is available on this page - http://www.parallax.com/tabid/832/Default.aspx
I wrote a C version of Remy Blank's python loader and included it in Catalina. It is called "payload". Catalina is available here - http://sourceforge.net/projects/catalina-c
With tongue in cheek I add that Sphinx is another command-line compiler.
