Using counter for inter-prop communication
Somebody clever (was it heater?) suggested using the counter as a means of fast communication between props.
I'm nearly done with a three prop configuration (Hive-Project.de) and am interested trying this.
So far, I haven't seen any discussion of actually doing it, I'd like to start the conversation. Please forgive if there is already a thread started, I haven't found it.
What are some references that will get us started on this?
How Fast Can you Make Your Propeller
Make a Faster I/O (Advanced Programmers Only)
Cogs Slow Down Prop?
Prop Chip Outside of a Prop Chip
Cog Speed
and Beau's comment is here
Beau Said, If were not talking about the number of I/O's then in theory using all 32 IO's you could transfer data from one propeller to another propeller using one COG at 320 Million Bits per second. 100ns for a 'fetch/move' = 10MHz ... times a 32 bit wide data buss = 320 Million Bits per second. The bottle neck being the number of IO's ... supposing you had 256 IO's, then with 8 COGS you could in theory transfer 2 Billion 560 Million Bits per second. (320 Million times 8).
Heater said, The topic of this thread is "How fast Can you make your Propeller?" Well you can write PASM code in COGs at attain whatever speed it is. But what if the counters can some how be used in conjunction with your PASM to enhance the speed of whatever you are doing? As has been suggested they can be used as auto incrementing pointers to speed up array traversal. I think a classic example of this is Phil Pilgrims radio receiver built with just a Prop and a couple of resistors/capacitors. For sure you could implement the algorithm he uses to do signal detection in PASM alone but it would be too slow to be of use. Drag the counters in to help and you have effectively multiplied the speed of the thing by a factor of 10 or whatever.
@Leon - Can you give more detail on how that's done? I'd like to come up with something that can be applied to the prop. Is there an article on the application of this capability?
