How to make a tiny spin program (at the top of the code) count the number of spin instructions automatically between two points in the middle of the code?
1) Put some "special" markers at the beginning and end of the Spin code sequence you want to measure the length of.
2) Then put a loop at the top of your Spin that searches all of HUB RAM for those special markers.
3) Take the difference between the found addresses of the markers and you have your Spin byte code sequence length.
No time to make a working example for you but here is how the markers might look:
PUB start | begin, end, a, b, c, d, e, f
'Put loop here to search HUB RAM for
'the location of LONGS containing $DEADBEEF and $BEEFDEAD
'in HUB RAM and the the byte code length is the difference
'between the addresses found minus a little bit.
a := 1
b := 2
begin := $DEADBEEF
c := 3 'Measure size of code btween begine and end
d := 4
end := $BEEFDEAD
e := 5
f := 6
When compiled this looks like:
7 a := 1
Addr : 0018: 36 : Constant 2 $00000001
Addr : 0019: 6D : Variable Operation Local Offset - 3 Write
8 b := 2
Addr : 001A: 37 00 : Constant Mask Y=0 00000002 2
Addr : 001C: 71 : Variable Operation Local Offset - 4 Write
9 begin := $DEADBEEF
Addr : 001D: 3B DE AD BE EF : Constant 4 Bytes - DE AD BE EF - $DEADBEEF 3735928559
Addr : 0022: 65 : Variable Operation Local Offset - 1 Write
10 c := 3 'Measeure size of code btween begine and end
Addr : 0023: 37 21 : Constant Mask Y=33 Decrement 00000003 3
Addr : 0025: 75 : Variable Operation Local Offset - 5 Write
11 d := 4
Addr : 0026: 37 01 : Constant Mask Y=1 00000004 4
Addr : 0028: 79 : Variable Operation Local Offset - 6 Write
12 end := $BEEFDEAD
Addr : 0029: 3B BE EF DE AD : Constant 4 Bytes - BE EF DE AD - $BEEFDEAD 3203391149
Addr : 002E: 69 : Variable Operation Local Offset - 2 Write
13 e := 5
Addr : 002F: 38 05 : Constant 1 Bytes - 05 - $00000005 5
Addr : 0031: 7D : Variable Operation Local Offset - 7 Write
14 f := 6
Addr : 0032: 38 06 : Constant 1 Bytes - 06 - $00000006 6
Addr : 0034: CD 20 : Memory Op Long DBASE + WRITE Address = 0020
Addr : 0036: 32 : Return
In the BST listing. You can see how those "marker" vlues are siting the code waiting to be found.
Of course this might fail if your code uses the marker values as well.
That code that i sugest looks for your start and end markers is sitting in yor program. Why would it not run automatically? It just needs haccess to a serial output to show the results.
Humanoido: Just use bst or homespun and use the listing option and you can count them.
However, if you want to count actual instructions (spin or pasm) used, you can use my zero-footprint debugger. It does not have breakpoints but it does count both.
No, I did not put five starts on this thread. I don't consider my byte code counting technique that clever.
I doubt anyone else has voted on this thread yet either.
There is a bug in the star rating system that apparently is known about and will be fixed at some point. See the support forum.
That's what my sugestion does, it finds the tokens and counts them.
