connecting Hydra to a USB TV video stick
I want to take my Hydra board along with me to use with my laptop, but I don't want to lug a TV around. I was thinking, could I use a USB TV video stick instead of getting a portable TV? Then connect the Hydra to it and view the output on my laptop's screen?
gb
http://www.gonzobrains.com
gb
it will have some latency though, ie, Hydra displays the image, which is read and scanned by the USB TV, which is then rendered to the screen buffer, which is then displayed on your laptop screen, other than the frame or two delay, it's fine!
Get a couple of rechargable 9V batteries, or a nice 4 AAA pack, and you are good to go. A lousy 9V battery will run your prop board for a coupla hours. A great one might go 4-6, depending on what you do with it.
USB video captures are either HD or SD. Get a HD one. You will appreciate the much improved captures over composite. I've captures all over this forum done that way.
Finally, there are some apps, like dscaler, that will render the video with only a frame or two of latency. The preview in many DVD authoring tools does this as well. You've just got to look around and try some software.
My best setup is a portable prop board, battery powered, with all the cables hooked up. You can connect the two USB cables, one for the Prop programming, one for the video / audio to the PC, and be off and running in a few minutes tops. I use a small carrying case, or pouch, with the cables maintained with twist-ties, or Velcro.
