Recording Logic Data
Hi Folks,
So I'm LOVING my propscope. Only since I've been able to see bits on the screen have I really "gotten it" with regards to I2C, SMBus, etc. Awesome!
One challenge I do have though, is that I have some circuits where I'm pumping out streams of bytes, and if I squeeze the scale enough to see the individual bits, I lose the beginning portions of the data exchanges.
Is there some way to record a whole series or communications? I just can't seem to figure it out. Any suggestions would be appreciated, even a reference to the user's manual
-Jeff
-Jeff
Right now the Propscope does a great job of capturing the high/low state of the data pins in the logic analyzer. But I haven't found a way to capture a string of say 8 bytes and still have the data be of sufficient resolution to view the actual bits. So really the question is:
How can I grab 10 seconds worth of logic data, and still have the resolution to dive into the individual bytes?
-Jeff
One thing that may help now is that the PropScope captures 2 screens of data and allows you to set the horizontal trigger to wherever you want- even at the end of the sample time. You can capture your data, then hit "stop", and with the mouse scroll the data back and forth- even change timescales.
I'm slowly working on decoding serial protocols- that will allow much more...
Hanno
