Accelerometer - deceleration
Hi, I am developing a device for bicycles that detects the deceleration of the bicycle and depending on this, a set of LEDS will be flashing and when the brake is hit, the lights go solid.
I have chosen atmega8 micro-chip, a memsic 2125 accelerometer to start with for the device. Problem is the memsic 2125 accelerometer is a dual-axis and i am a bit confused with the connections (especially the x-axis and y-axis. i m not sure where they go from the wheel/wherever)
Thanks a lot...Please help...!!
I've been thinking the same thing. But it has also occurred to me that the OP's overall objective might be to eliminate any external wiring which, on a bike, can present it's own reliability issues. The idea of a completely self-contained brake light mounted on the rear of the bike does have its attractions.
I have considered ADXL202 and MEMSIC2125 accelerometers but both are very expensive. I am stuck on this one bit.
If you watch the rate of change of the G forces on an accelerometer you'd probably find that braking lives somewhere in the realm between bumps in the road which would be very fast short lived changes and tilt of hills which would be slow and long lived changes.
I guess that would be the "derivative of acceleration".
Any chance he could aim something like a bright IR diode at the rear tire and "read" the recurring pattern of light pulse fluctuations reflecting from the tire tread, store said fluctuations as a bit pattern or whatever, monitor them continuously, then flash the freak out lights when the pattern gets suddenly shifted in a manner suggestive of a braking scenario?
Just thinking out loud.
Or how about a Piezo Vibra Tab sensor in the spokes, which will also make that cool motorcycle sound!
I'd be a little concerned about mechanical fatigue shredding the thing after a few days (hours?).
Or, use a switch.
In the instant before I caught sight of your punch line, I actually pitied you for having tried all of that and achieved your 77%.
Very funny!
