Can the PING ULTRASONIC DISTANCE SENSOR BE USED OUTDOORS?
For instance, on the outside wall of an RV (camper, travel trailer).
When I turn sharp corners I need to know how close my RV side is to an object, such as a large garbage dumptser. I pull the camper with a truck, and have had holes poked in the side of the camper by close objects while making a sharp turn.
Can the PING ULTRASONIC DISTANCE SENSOR (#28015) be installed on the outside wall of an RV (camper)?
Thank you
po2le
Thank you
po2le
Is there any kind of sensor that could be used for the purpose I mentioned?
Your address led me to a company that has a large selection of ultasonic sensors.
po2le
Maybe seeing how they did it would help.
Yes, we were working on a weather resistant Ping))) a while back, but some priorities had to be changed if memory serves. I asked around a bit and nobody is actively working on it for now.
As for installing the ping on a camper, not a bad idea
I am working on a battery powered propeller board now and that board has only 3.3v supply?
How now?
