sending multiple values from stamp to visual basic
hi!
i want to send 2 temperatures from my BS2 to a my program in visual basic...
so far one value is working perfect using the serout command in pbasic and in visual basic i used mscomm...from rentron.com
how should the code look like?
regards
Robert
regards
Robert
Typically, to send one value from a Stamp to a PC, you'd use a SEROUT statement with one value followed by some kind of delimiter like a space or a comma or a carriage return. To send two values, you'd do the same thing, either using two SEROUT statements or a single SEROUT statement with two values like
SEROUT ...,[DEC value1," ",DEC value2,CR]
how do i get it into visual basic
i use a program this program....see link.
http://www.rentron.com/receiving_data.htm
in this program it says that i should use highbyte and lowbyte....
is there an easier way or what should i add to my program..
the bs2 program look the same as in the rentron program although i use the temperature instead.
dont know how to attach but here´s the program
' {$STAMP BS2}
' ===================== Define Pins and Variables ================
DQ CON 2 ' Pin 2 <=> DQ.
CLK CON 1 ' Pin 1 => CLK.
RST CON 0 ' Pin 0 => RST (high = active).
DSdata VAR Word ' Word variable to hold 9-bit data.
Sign VAR DSdata.BIT8 ' Sign bit of raw temperature data.
T_sign VAR Bit ' Saved sign bit for converted temperature.
' ===================== Define DS1620 Constants ===================
' >>> Constants for configuring the DS1620
Rconfig CON $AC ' Protocol for 'Read Configuration.'
Wconfig CON $0C ' Protocol for 'Write Configuration.'
CPU CON %10 ' Config bit: serial thermometer mode.
NoCPU CON %00 ' Config bit: standalone thermostat mode.
OneShot CON %01 ' Config bit: one conversion per start request.
Cont CON %00 ' Config bit: continuous conversions after start.
' >>> Constants for serial thermometer applications.
StartC CON $EE ' Protocol for 'Start Conversion.'
StopC CON $22 ' Protocol for 'Stop Conversion.'
Rtemp CON $AA ' Protocol for 'Read Temperature.'
' >>> Constants for programming thermostat functions.
RhiT CON $A1 ' Protocol for 'Read High-Temperature Setting.'
WhiT CON $01 ' Protocol for 'Write High-Temperature Setting.'
RloT CON $A2 ' Protocol for 'Read Low-Temperature Setting.'
WloT CON $02 ' Protocol for 'Write Low-Temperature Setting.'
Kal CON 11550 ' Constant to be determined.
rct VAR Word ' A word variable.
TK VAR Word ' Kelvin temperature.
TC VAR Word ' Degrees Celsius.
result VAR Word
' ===================== Begin Program ============================
LOW RST ' Deactivate '1620 for now.
HIGH CLK ' Put clock in starting state.
PAUSE 100 ' Let things settle down a moment.
HIGH RST ' Activate the '1620 and set it for continuous..
SHIFTOUT DQ,CLK,LSBFIRST,[Wconfig,CPU+Cont] ' ..temp conversions.
LOW RST ' Done--deactivate.
PAUSE 50 ' Wait for the EEPROM to self-program.
HIGH RST ' Now activate it again and send the..
SHIFTOUT DQ,CLK,LSBFIRST,[StartC] ' Send start-conversion protocol.
' The loop below continuously reads the latest temperature from
' the DS1620.
again:
PAUSE 1000 ' Wait a second between readings.
HIGH RST ' Activate the '1620.
SHIFTOUT DQ,CLK,LSBFIRST,[Rtemp] ' Request to read temperature.
SHIFTIN DQ,CLK,LSBPRE,[DSdata\9] ' Get the temperature reading.
LOW RST
T_sign = Sign ' Save the sign bit of the reading.
DSdata = DSdata/2 ' Scale reading to whole degrees C.
IF T_sign = 0 THEN no_neg1
DSdata = DSdata | $FF00 ' Extend sign bits for negative temps.
no_neg1:
result=dsdata
DSdata = (DSdata */ $01CC) ' Multiply by 1.8.
IF T_sign = 0 THEN no_neg2 ' If negative, extend sign bits.
no_neg2:
DSdata = DSdata + 32 ' Complete the conversion.
'***** check ad592 sensor*****
LOW 15 ' Discharge the capacitor.
RCTIME 15, 0, rct ' Time for the volts to rise to 1.3 V.
TK = Kal/rct*10 + (Kal//rct*10/rct) ' Calculate Kelvin
TC = TK - 273 ' and Celsius.
PAUSE 50 ' Slows down the program.
SEROUT 16,16780,[result.HIGHBYTE,result.LOWBYTE]
GOTO again ' Repeat forever.
Serout 16,16780,[Result.HighByte, Result.LowByte]
In order to send two values, you'd just repeat the SEROUT statement with your other variable instead of "Result". That sends a total of 4 bytes, 2 for each value.
On the PC side, you'd need to modify this code to allow for 4 bytes
Typically by following that with Remember that this is a fairly "primitive" way for two programs to communicate. There's no error checking. There's no synchronization mechanism. The PC program has to get 4 bytes when it expects it. You might have a look at StampPlot Pro for more complex communication between a Stamp and a PC.
thanks alot!
and now i want to control a fan using sering on the basic stamp side and visual basic on the computer side...
i have a faceplate in VB where i have the temperatures and if the temperature goes to high i want to be able to push a command button and start the fan.
i have tried serin,,,[pinstate]
so if the pinstate are 1 then the fan starts
and if it is 0 the fan stops.
question is...everytime the stamp goes to serin the program stops and wait´s for a command from VB, how do i get it to continue read the temperatures and at the same time check if the command is sent without paus.
The only solution is to attach some kind of external serial receiver to the Stamp that provides buffering and otherwise runs all the time. Options include this from ProteanLogic and this from Microchip.
One other possible solution is for the Stamp to poll the PC for the state of your on/off request. In other words, when the Stamp sends a set of two values to the PC, the PC always sends a byte back to the Stamp whose value is 0 or 1. After the two SEROUT statements, the Stamp always does a SERIN which doesn't have to wait because there will always be a byte sent from the PC. The Stamp can compare the value received with the current state of the fan and act accordingly.
here´s my bs program
' {$STAMP BS2}
Kal CON 11225 ' Constant to be determined.
result VAR Word
pinstate VAR Byte
' the DS1620.
Main:
LOW RST
no_neg1:
result=dsdata
no_neg2:
' send it to VB
SEROUT 16,16780,[tc.HIGHBYTE,tc.LOWBYTE]
' check on or off from VB
SERIN 16,16780,2000,main,[pinstate]
IF pinstate=1 THEN gohigh
IF pinstate=0 THEN golow
GOTO main ' Repeat forever.
gohigh:
HIGH 12
GOTO main
golow:
LOW 12
GOTO main
i have about 10 sensors wired to the bs2 and 10 labels in Visual basic
but when i transfer the data the value from sensor 1 shows in label 3,then sensor 2 at label 4 or sometimes sensor 3 at label 1.
i want them the show sensor 1 at label 1,2 at label 2 ,3 at label 4
a piece of my vb program
' If comEvReceive Event then get data and display
If MSComm1.CommEvent = comEvReceive Then
sData = MSComm1.Input ' Get data (2 bytes)
lHighByte = Asc(Mid$(sData, 1, 1)) ' get 1st byte
lLowByte = Asc(Mid$(sData, 2, 1)) ' Get 2nd byte
label1 = (lHighByte * &H100) Or lLowByte
lHighByte = Asc(Mid$(sData, 3, 1)) ' get 1st byte
lLowByte = Asc(Mid$(sData, 4, 1)) ' Get 2nd byte
' Combine bytes into a word
label2 = (lHighByte * &H100) Or lLowByte
lHighByte = Asc(Mid$(sData, 5, 1)) ' get 1st byte
lLowByte = Asc(Mid$(sData, 6, 1)) ' Get 2nd byte
'Combine bytes into a word
label3 = (lHighByte * &H100) Or lLowByte
label1.caption=label1
label2.caption=label2
label3.caption=label3
robban
You'll need to check the serial port buffer and make sure it contains all the bytes required to populate the VB form. A good way to align the serial buffer and VB form logic is to send a start byte, number of bytes to expect, followed by the data 10 bytes, and ending with a checksum.
serout 15,84,[result.highbyte,result.lowbyte,0]
and then in VB
if sdata=0 then next value?
could you give me an example?
Example packet:
Start length [ data ] checksum
! 10 [1,2,3,4,5,6,7,8,9] 1
The idea is to frame the incoming byte stream. Then extract the data for use in the Win Form.
serout 15,84,["!",result.highbyte,result.lowbyte,0]
You could do if the "0" is the index of the value - result . On the VB side, the program will know here to place the value of result.
this is a peice of my vb program
Private Sub Form_Load()
Dim Pins As Long
' Fire Rx Event Every Two Bytes
MSComm1.RThreshold = 28
' When Inputting Data, Input 2 Bytes at a time
MSComm1.InputLen = 28
' Use COM1
MSComm1.CommPort = 1
' 2400 baud, no parity, 8 data bits, 1 stop bit
MSComm1.Settings = "9600,N,8,1"
' Make sure DTR line is low to prevent Stamp reset
MSComm1.DTREnable = False
' Open the port
MSComm1.PortOpen = True
utetemp = (lHighByte * &H100) Or lLowByte
innetemp = (lHighByte * &H100) Or lLowByte
jordtemp = (lHighByte * &H100) Or lLowByte
lHighByte = Asc(Mid$(sData, 7, 1)) ' get 1st byte
lLowByte = Asc(Mid$(sData, 8, 1)) ' Get 2nd byte
kond1 = (lHighByte * &H100) Or lLowByte
lHighByte = Asc(Mid$(sData, 9, 1)) ' get 1st byte
lLowByte = Asc(Mid$(sData, 10, 1)) ' Get 2nd byte
kond2 = (lHighByte * &H100) Or lLowByte
lHighByte = Asc(Mid$(sData, 11, 1)) ' get 1st byte
lLowByte = Asc(Mid$(sData, 12, 1)) ' Get 2nd byte
kond3 = (lHighByte * &H100) Or lLowByte
lHighByte = Asc(Mid$(sData, 13, 1)) ' get 1st byte
lLowByte = Asc(Mid$(sData, 14, 1)) ' Get 2nd byte
kond4 = (lHighByte * &H100) Or lLowByte
lHighByte = Asc(Mid$(sData, 15, 1)) ' get 1st byte
lLowByte = Asc(Mid$(sData, 16, 1)) ' Get 2nd byte
kond5 = (lHighByte * &H100) Or lLowByte
lHighByte = Asc(Mid$(sData, 17, 1)) ' get 1st byte
lLowByte = Asc(Mid$(sData, 18, 1)) ' Get 2nd byte
fukt = (lHighByte * &H100) Or lLowByte
lHighByte = Asc(Mid$(sData, 19, 1)) ' get 1st byte
lLowByte = Asc(Mid$(sData, 20, 1)) ' Get 2nd byte
ljus = (lHighByte * &H100) Or lLowByte
lHighByte = Asc(Mid$(sData, 21, 1)) ' get 1st byte
lLowByte = Asc(Mid$(sData, 22, 1)) ' Get 2nd byte
niva = (lHighByte * &H100) Or lLowByte
lHighByte = Asc(Mid$(sData, 23, 1)) ' get 1st byte
lLowByte = Asc(Mid$(sData, 24, 1)) ' Get 2nd byte
larm = (lHighByte * &H100) Or lLowByte
lHighByte = Asc(Mid$(sData, 25, 1)) ' get 1st byte
lLowByte = Asc(Mid$(sData, 26, 1)) ' Get 2nd byte
status = (lHighByte * &H100) Or lLowByte
lHighByte = Asc(Mid$(sData, 27, 1)) ' get 1st byte
lLowByte = Asc(Mid$(sData, 28, 1)) ' Get 2nd byte
auto = (lHighByte * &H100) Or lLowByte
Label1.Caption = CStr(utetemp)
Label2.Caption = CStr(innetemp)
Label3.Caption = CStr(jordtemp)
Label4.Caption = CStr(kond1)
Label5.Caption = CStr(kond2)
Label6.Caption = CStr(kond3)
Label7.Caption = CStr(kond4)
Label8.Caption = CStr(kond5)
Label9.Caption = CStr(fukt)
Label10.Caption = CStr(ljus)
Label11.Caption = CStr(niva)
Label23.Caption = CStr(auto)
i think i understand your program,mike but i cant figure out how to get it in my vb program
where is the fault
the bs2 program is attached
The VB application must parse the serial buffer and handle any missing or extra data.
Secondly, consider researching asynchronous serial communication in Windows. I believe this is where you are having difficulty. If I get some time, I'll try to roll up the concept in .NET - C#.
You must update the VB 6 and possibly PBASIC code. In posts 10, 12, 14 and 16 I tried to explain the problem. Do you understand the problem?
thanks!'
