Running multiple servos at the same time?
I'd appreciate your advice with this question. I want to run three servos at the same time, each with their own routine. All the program examples I have looked at have them going one at a time. Can someone point me towards an appropriate help file or something?
Tracy
Tracy
a: pulsout 1,nnn' servo 1
pulsout 2,mmm' servo 2
pulsout 3,ppp' servo 3
pause 20
goto a' loop back
and the rest of your program has to be "minimally invasive" to that loop to keep the 3 pulse streams going strong. You may have to decrease the pause 20 if you have a lot of operations going on.
http://www.parallax.com/StoreSearchResults/tabid/768/txtSearch/servopal/List/0/SortField/4/ProductID/481/Default.aspx
You send a single pulsout per servo, and the ServoPal endlessly repeats the necessary regular string of pulses to get it to or hold that position. One ServoPal can control 2 servos.
Plus, it has an extra alarm function so that Br'er Whit won't burn his biscuits anymore.
ServoPAL - Item code 28824
http://www.parallax.com/StoreSearchResults/tabid/768/txtSearch/servo/List/0/SortField/4/ProductID/481/Default.aspx
Propeller Servo Controller USB - Item code 28830
http://www.parallax.com/StoreSearchResults/tabid/768/txtSearch/servo/List/0/SortField/4/ProductID/595/Default.aspx
With either of these you just tell them what to do with the servos and avoid the whole issue of having to constantly update the low level servo pulses over and over again.
Robert
