5v inputs or outputs with a 3.3v prop (5 volt)
The tread called 'how to safely interface 5v to the prop" seems gone.
Simple solution seems that you put a 1k resistor in series for inputs.
But if you have to use external logic anyway
like a multiplexer or shift register
There are 74VHC chips that can handle
these voltage difference for you.
http://www.fairchildsemi.com/ds/74/74VHC153.pdf
http://www.fairchildsemi.com/ds/74/74VHC595.pdf
The 74LVC seems to mix 3.3v and 5v nicely too.
http://www.nxp.com/documents/data_sheet/74LVC595A.pdf
I'm not sure if VLC or VHC is best for the prop?
The 8-to-1 mux I can only find in HC151,
How would I use that one with 5v inputs (they are from a open collector source if need to know)
Try this link
"How to safely interface a 5V signal to the Propeller"
Click on it and it just brings you back to forum front page.
Update: your link works.
But I still would like to see a official guide about 5V interfacing.
,and not some random Q&A in a thread.
