Help with time delay
I have a code loop in spin that interfaces with an assembly language routine.
The loop is designed to call an adc routine to supply adc values to the assembly language routine thru shared variables.
The loop needs to run continuously until x_step and y_step are both zero (two stepper motors running at 30KHz micro-steps).
What I'm trying to do is call a display routine every 0.1 seconds while it's looping, to show current values supplies by the assembly routine.
Here's my question: The variable disp_cnt may wrap around when it overflows the 32 bit register. It seems like this would make it so the "if cnt > disp_cnt" statement wouldn't work right. What is the right way to handle this, so the if statement always works?
Thank you for your help.
Jim
Jim
disp_cnt := cnt + clkfreq/10 ' add 0.1 second to cnt repeat while x_steps or y_steps ' wait for assy routines to finish get_lim_sw_adc_values ' call the adc routine to get switch values for assy routine if cnt > disp_cnt ' display now and then disp_cnt := cnt + clkfreq/10 ' reset timer, add 0.1 second to cnt display_table_loc(30,220,200,240) ' display table location in microns: +/- uuu.u if (x_mot_err or y_mot_err) ' set by assy routine x_t_loc := x_mot_err ' table location for X/Y calibration at lim switch y_t_loc := y_mot_err quit ' break if we hit a limit switch
Thank you for the quick reply.
This has always bugged me, but I never took the time to figure it out.
Jim
