RFID trouble
Hi, I haven't used the BS2 in a while but just made a deal with ravenkallen and got a RFID in it. I'm trying it on a board that i don't think is broken (BOE) with a 4 AA battery supply and when i hook up the RFID reader the power light turns off, it cant supply enough power to the RFID reader. The RFID reader is new and i just un-packaged it and i don't know why it isn't working, i used the RFID basic program pin out and it just seems screwed, or am i making a stupid mistake? Any help?
I cannot vouch for your batteries or your Reader, but attached are a couple of pictures the BoE and the RFID Reader powered on. Not a lot of wires, not much to mess up.
Vcc and Vdd are often used to refer to the same thing, the positive supply voltage. I think the "cc" dates back to bipolar logic when the supply voltage was connected to the transistor's collector. I think that the "dd" came into use with FETs with the FET's drain terminal taking the place of the collector.
Vss and ground are used to refer to the same thing, the ground or negative supply voltage. "ss" refers to "substrate" when you needed a ground connection to the chip's substrate (usually the back of the chip).
(CPBS, see attachments,... for naught)
PE - http://www.youtube.com/watch?v=FKHdhZuIov8
logan996 said: "vcc connected to vss. /enable connected to pin 0. sout connected 1. gnd connected to vdd "
EDIT: now i can't upload code when the reader is plugged in and when i plug it in after i upload the code, then it stops working and when i reset it wont even try to talk to the terminal anymore but the reader is fine! the green light is on and when i plug it in midway through the program it will turn red then green!
The fact that the RFID reader works for others with the BS2 and with the BOE suggests that there's something wrong with your specific setup, perhaps your batteries. It's impossible to tell without further information.
Or is there a reader that can do this?
Thanks.
TIm
