Why such large output capacitors on PE Kit board?
I understand (at least mostly) why output capacitors are necessary on voltage regulators, but I'm not clear as to why the capacitors on the PE Kit board are of such a high value. I'm used to seeing anywhere from 0.1uF to 10uF output capacitors, so I'm confused as to why the PE Kit board uses 1000uF capacitors. Can someone help me understand the electronic reasoning why this value of capacitor is used in the PE Kit circuit?
