A little help on wiring a relay switch
Hello,
I've been searching through the forums and really didn't see a possible answer for a question I have. I am trying to figure out how to wire a battle switch from Dimension Engineering to my propeller, the specs are:
Max relay voltage: 240VAC
Max relay current: 10A @ 28VDC, 12A @ 120VAC, 10A @ 240VAC.
Relay resistance: 100 mΩ max
3.5V to 5.5V operating voltage (on servo pigtail)
30mA typical draw from receiver
Specifically I am not sure if I should be using a 4.7k or 10k resistor when hooking the signal wire up to my Propeller.
My robot has a spearate power supply for the motor controller/motors and I would like to be able to shut this off when the robot is doing other things.
There are two numbers you've given that might have to do with activating the relay, the operating voltage (3.5V to 5.5V) and the typical draw from the receiver (30mA). Nowhere do you indicate how this relay works. Most typical relays have a coil and, when current is sent through the coil, an armature is pulled in which makes contact with a fixed contact and that's how a large current is controlled by a smaller one. Your info talks about a servo pigtail and a receiver and that doesn't make sense unless you're talking about a servo motor that mechanically throws a switch.
How about a link to a datasheet on this switch?
On a side notice: Propeller's CMOS voltage differental driver (TTL to ECL logics already on-die) is good for up to 30mA and relay switch's coil usually consume lot of juices so it's not a good idea to directly drive it. I have driven a high voltage transformer via the transistor, with its base tied to Propeller chip, and it worked, so it oughta work with the relay switch.
Now, if it is just a relay then you need to let us know the specs on the coil (voltage, etc) and with that we can give you some options for driving it. I usually prefer adding an opto-isolator (something like a 4n26) to protect the Propeller chip.
Robert
http://www.dimensionengineering.com/BattleSwitch.htm
This is a R/C controlled relay switch that you can use from an R/C setup, and I assumed that I could use this with the propeller with a resistor
Thanks again!!
Thank you so much!! I just got done wiring it up and it works perfectly!! Again thanks to everyone who responded, it's been just over a year since I was able to work on my robot, and things are starting to come back to me, just not as quicky as I would like them to...
