RFID tags Waterproof???
Are the RFID tags that Parralax offers waterproof. I have a project that will involve tracking items that are stored in water for days at a time. Will the tags hold up in this environment?
Thanks for the replies!
We obtain these tags from two different suppliers, one in Norway and another in China.
Could you tell me which specific Parallax part number you're considering using?
I received the following response back from our supplier for the 20mm Round Tag (32398), 30 mm Round Tag (32399) and 50 mm Round Tag (28442).
"The World Tag is not waterproof. Depending on how much moisture or water gets inside the tag it will either keep working or come back alive after it dried out. If the tag is exposed to freezing temperatures while moisture / water is trapped inside it will bust."
I will be sure to revise the product descriptions to indicate that these are not waterproof.
Still waiting for a reply on the other tags we offer.
http://www.plastidip.com/
I received confirmation from our other supplier in China that their tags are also not waterproof. As they described it "the tag cannot have taken a shower in the water for days. But, if it drops in the water accidentally and then it is picked up right away, the tag will still work."
This seems to be true of all of our tags.
Robert
I'll check to see if I have any of the 25mm or 50mm white tags and throw them in the x-ray to see where the "safe-spot" is to drill a mounting hole so they can be used like the World Tags, yet be waterproof.
i can say that this stuff does work for waterproofing certain things, as long as there isn't too much friction or abrasion on the item coated. i made a ground temperature sensor using 3 strands of 18ga insulated solid core wire with 3 dallas ds18b20's soldered directly to the wire at ground suface level, 4" and 10" intravals, then used the spray version to coat the entire strand. it's still working after 2 years in the ground and being moved twice. i would think it would work fine for this application.
It stands up to the hot water with no problem. Not pretty since the rack is white and the Plastidip is black...
