PropBasic: INC — Parallax Forums
PropBasic: INC
VonSzarvasVonSzarvas Posts: 3,639
edited 2010-09-08 06:14 in Propeller 1
I tried this:
tmpa(7) = 196
SD_sectorsize = 33536
INC SD_sectorsize, tmpa(7)
BUT- The INC did not occur, the SD_sectorsize remains at 33536
Then I did this:
INC SD_sectorsize, 196
And it worked fine. SD_sectorsize = 33732
I could pass my array to a single byte... but should this work ?
Thanks!
  • BeanBean Posts: 8,129
    edited 2010-09-08 06:10
    Maxwin,
    Hmmm, yeah that should work. But it doesn't.
    I'll check into fixing that in the compiler.
    Thanks for finding that bug.
    For now just use this instead:
     SD_sectorsize = SD_sectorsize + tmpa(7)
    Bean
  • VonSzarvasVonSzarvas Posts: 3,639
    yep, that code is a neater solution than passing to a byte first!
    Thanks.
