Vibration Motor on a Prop
I am working on a project using the Gadget Gangster Prop Module SD.
The device will be in a small hand held case and I need to give the user some feedback.
I would like to do this with a small Vibration Motor.
http://www.pololu.com/catalog/product/1638/specs
I am fairly new to all this so my question is as follows.
The Propeller pins has a 40 mA max.
The Vibration motor pulls 60 mA.
If I understand all this correctly, I cannot connect the vibration motor directly to the CPU pin.
I'll need to have a switch (ie relay) connected that will turn the vibrator on and off.
Is that correct? If so, any recomendations? Relay, Transister, ????
Thanks in advance.
Ben Clark
Thanks in advance.
Ben Clark
It's not only 60mA. Look like at 3.3V it can go up to 80mA (See notes).
The simplest solution here is to use a transistor. Don't need a relay for that.
Just put a 2N2222 between your propeller and your motor, and that will do the job.
JM
Thank you both for the quick reply.
What Leon is talking about is a flyback diode. See the following for more info:
http://en.wikipedia.org/wiki/Flyback_diode
