How could I wirte data to a SD card and then later retrieve?
How could I wirte data to a SD card and then later retrieve the data to be used in a spin program? Basically I want to use nick's magic ir object to record the ir signal and save it to an SD card. Then go back to the SD card and play the signal back. I am able to write to the SD card, but I am not sure how to get the data back into the program to use. I am using fsrwFemto as my object to read and write to the SD card.
Thank you,
CameronM
Thank you,
CameronM
Thank you,
CameronM
Thank you,
CameronM
Thank you,
CameronM
