Harbor Freight
I tried shopping at Harbor Freight and bought a sump pump for $39.99. I is a half horsepower sump pump by the brand name Pacific Hydrostar and it had to be primed. Nothing on the box or the instructions said it had to be primed and I had tested the unit in a tub. It has one of those float switches so if it has to be primed then they are wasting their time with a float switch.
For those of you trying to help others by recommending Harbor Freight, thanks. But the reason some items are low cost is because they don't perform.
Sump pumps should be located in a hole in the floor. If the float switch is high enough there will still be water in the hole and you should not lose your prime. You do have a point though, you get what you pay for.
Like Irone said, sump pumps are designed to be placed in a hole in the floor (the sump part of the name) and to come on only when the hole fills with water, which is what primes them, so you probably would have the same experience with a similar product by any other brand.
Many other items are just junk. Buyer beware...
Hope this helps
Regards
Chet
I miss it.
If it is made of plastic, is electronic or involves anything but the most basic mechanisms, then there is an extremely high chance that the product will under perform or not last long.
Many of the things that I have purchased there I have done so with the mindset that I am just getting the materials to make what I want. If you are willing to put in some of your own time, some of the stuff can me made to work well.
The only thing that I can recall that has worked well out of the box for many years is the metal cutting bandsaw. I have had it for over ten years and have never had a problem with it, nor have I had to modify it or correct a defect.
Rich H
And their $15 cordless drills are a must-have. Even if you use it a lot and kill it in a year, buying a whole replacement is still less than just a replacement battery for a Craftsman or Ryobi, which often go bad in a year or two.
1. Exploring possibilities in a cheap fashion - try HF
2. Acquiring good solid equipment to be used over the long haul - forget it.
I recently had a need to polish some small stone slabs; generally this is done with a flat lap, which is a large machine that needs several large expensive wheels or a lot of care with abrasive grit. I got the idea of trying the plasticized pads that are used to polish granite countertop edges. These are meant to be mounted on rotary grinding heads that feed water through the center of the spindle, and those things are pricey. But I got HF's cheapest little sander, mounted a plastic block under it with some plumbing channels drilled and more hook-and-loop, and for under $20 got it polishing. I wasn't bothered by destroying the sander to try the experiment because it was under $20; the cheapest similar item from a more respectable local store was over $40. It's for things like that HF really can't be beaten.
I'm not impressed with their cutting tools such as a drill index , dremel like attachments or router bits etc. and would not buy them there.
They do get a thumbs up for a small utility trailer I recently bought and 5 stars for their pneumatic flooring stapler/nailer , when I bought the nailer I got it for $99 in one of their sales ( a similar Bostich unit is almost $500 ) , it worked flawlessly on 1000 square feet of 3/4 hardwood flooring.
Jeff T.
the Brackets were nice . Amorphous so there not great on the Power to size but I used 3 Of them with a Ibook G3 Clamshell on a camping vacation .To run right off the sun for days !
the collection box as a diode in it and some Nice studs to attach the wire of your choice.
I payed like 24 per panel . not bad IMHO
I bought several yellow ones that
have LED backlighting. They were
3 dollars I think, and they work
very well. The only thing they needed
was a continuity test setting with an
audible tone...I use that a lot. They also sell
a nice clamp meter for about 10 dollars
and they are pretty accurate when
measuring AC amperage.
