Please tell me why this doesnt work well.
This is a simple program to read the time between 3 low to high transistions.
pin 1 is used to start it via a button.
pin 2 in input for the signal.
im using the pulse generator output on the professional development board ran through a button.
when i run the program i push the button on pin 1 to start the rest of the program. then i push the button to let the signal from the pulse generator feed to pin 2. program takes measurements on the first 3 low to high. Problem is that using the terminal to view the result I'm seeing inconsistant results. I would think if I feed the measurement with a pulse generator signal then the counts between pulses should be very close. But there off from alittle bit to sometimes alot. I dont know what I doing wrong. I'm very new at this. Please help.
thanks
thanks
repeat if buttonpin == 1 waitcnt(100_000) if buttonpin == 1 'run your code repeat until buttonpin == 0See how repeat is used in the propeller manual and how the lines under it you want to repeat are spaced over.
