Another Question — Parallax Forums
Another Question
logan996logan996 Posts: 281
edited 2010-09-04 08:07 in Propeller 1
I'm looking at 12 blocks and i cant remember a simple schematic for hooking up a button to the PDB (if possible could you provide a real pic, of it breadboarded? I have a lot of trouble with 4 prong buttons) and how do i hoop up a servo
    edited 2010-09-03 18:08
    Consider, next time you go to Radio Shack, picking up the little project box, some panel switches (pushbuttons/toggles) and some solid hook-up (#22, 24) wire. Drill the box to hold the switches and solder a 12_inch wire to each, bringing back the free ends to plug into your breadboard. More accessiblilty, less... fatigue, exasperation, etc.
  • logan996logan996 Posts: 281
    edited 2010-09-03 18:16
    Actually thats a good idea PJ, but do you happen to have a 2 prong button schematic (or a 4 prong would be even better) something to make during this labor day weekend
    edited 2010-09-03 18:18
    Isn't that in the PEK Labs book? That has good pics. I'll go look for it. You too.
    edited 2010-09-03 18:30
    Here's your situation:
    see attached
    622 x 482 - 107K
    edited 2010-09-04 07:07
    Exactly! Thanks PJ! to hookup a servo to a Demo board do i need any caps or resistors or do i just attach the + to 5v, Gnd to Gnd (of course) and the signal wire into one of the props pins?
    edited 2010-09-04 07:19
    No capacitors necessary. I think a small value resistor (100 ohms, brown-black-brown) between the Prop_pin and the servo SIGnal pin never hurt anybody, just some insurance, you can go without it.
  • CannibalRoboticsCannibalRobotics Posts: 535
    I have a file "Algorithms and Circuits". When ever I have trouble with something simple like this, I note it in the file. I've gone back to it a zillion times for stuff like NPN and PNP E,B,C hookups and bias resistor placements. OR, if I come with a cool solution for something, I stick a copy in the file. It's amazing how fast you can forget stuff.
    Glad you got your answers.
