Scribbler PWM Frequency — Parallax Forums
ercoerco Posts: 20,261
edited 2010-09-13 20:10 in Robotics
Anybody know the PWM frequency of the original Scribbler's motor drivers? That is, the freq of the power pulses received by the motors?
I can tear one apart and measure it (and I WILL if I have to), but surely someone in these hallowed halls knows the answer!
The reason? I have a trick up my sleeve to get dynamic braking on Scribbler. The two motors always coast different amounts when you shut them off, and the robot invariably turns.
I'm happily confident that PhiPi anticipated this and fixed it on S2!
    edited 2010-09-03 19:24
    erco,
    For each motor driver channel on the S2, the inputs are Motor_DIR and Motor_PWM. Consequently, the only way to get dynamic braking on the S2 is to reverse the motor directions momentarily (a brutish technique, which the S2 object does not perform). There's no hardware mode simply for shorting the motor coils to effect braking that way. That said, there is a ramp-down at the end of every motion profile, and I've seen no evidence in my experiments with the S2 proto that post-drive drift is an issue.
    As to the Scribbler I question, I have no idea. The PWM was handled by a Chinese PIC processor knock-off. You'll probably just have to get your scope out and take a look.
    edited 2010-09-03 22:47
    PhiPi: As usual, you're spot on. I want to short the motor leads together for dynamic braking (as opposed to dynamic BREAKING by reversing the motor polarity). I plan to use a SPDT relay on each motor to disconnect one power lead and short the motor with the NC contact. The relay will be controlled by a 555 timer in a missing pulse detector configuration. That is, any PWM drive signal will get routed to the motor, but when the PWM stops, the relay clicks over to brake the motor.
    I'll probably use a 556 since I need two 555s for 2 motors anyway. So I need to tune the missing pulse detector circuit to the PWM frequency.
    edited 2010-09-04 10:59
    That is a cool idea.
    edited 2010-09-04 23:33
    My counter says 99 Hz, if anyone wants to know.
    Now it's just a matter of time before my Scribbler becomes self-a-way-uh, as the Governator would say it.
  • WhitWhit Posts: 4,191
    edited 2010-09-05 18:43
    Great info erco!
    Long live old blue! Wecome new Scribbler 2!
    edited 2010-09-05 18:57
    @Whit: I can't be bothered waiting for S2 and its many vaguaries.
    I have several S1s and their time is nigh.
    I fully intend to outdo a stock S2's dead reckoning ability with old Blue and my Pathfinder software.
    Have you seen the Lost in Space episode entitled "War of the Robots"?
    edited 2010-09-06 08:17
    Get after it erco! I have some Scribbler accessory ideas that will work with either model.
    Here is the Lost is Space episode - http://www.hulu.com/watch/139/lost-in-space-the-war-of-the-robots I am going to watch it asap.
    Edit - LOL! What a classic...I guess old blue with never be out of style.
    edited 2010-09-06 08:35
    I have a 1-servo claw/arm solution that will work on both models! You saw it on Wastebot!
    edited 2010-09-06 09:39
    Cool idea!
    edited 2010-09-07 15:08
    What a difference a brake makes! Dynamic braking works quite well, as I have espoused many times before:
    http://www.youtube.com/watch?v=hGQEzz8CNIQ
    I opted to forego my previous scheme of missing pulse detection for flexibility and retaining the coasting option. I hard-wired one DPDT braking relay to pin 1, formerly the center photocell. In this simple arrangement, both wheels are braked at the same time. My 2 wheel encoders (pardon me, Wikipedia, tach sensors) are wired in place of the left & right photocell.
    To use pin 1 as an output, I had to bypass the series SMT 220-ohm resistor and clip the center photocell lead. That's one of my 17 mA Aromat relays, so no driver transistor is needed.
    BTW, this is a heavily modified Scribbler. In addition to the wheel encoders & braking mods, it has lower ratio gearmotors wired backwards (for quicker response), and built-in external charging contacts and a charge indicator LED, per my article at http://www.botmag.com/articles/scribbler.shtml
    And I ain't done yet!
    @PhiPi: According to "Hacker's Hints" PDF on the Scribbler, it uses PCM, not PWM. Does that sound right?
    "Drive Motors – Motors.bs2
    The Scribbler moves when velocity instructions are sent to both the right and left DC motors.
    These motors are controlled by Pulse Code Modulation (PCM) signals using the PULSOUT command.
    PULSOUT Pin, Duration
    Pin will be either MotorRight or MotorLeft. Duration defines the signal pulse width, in 2
    microsecond units. The DC motors will accept a Period value between 1000 and 3000.
    These DC motors use PCM, where hobby servos use PWM (Pulse Width Modulation). "
    800 x 600 - 70K
  • agfaagfa Posts: 295
    edited 2010-09-07 16:37
    Nice work erco! It looks quite effective. Did it eliminate the uneven stopping problem? I would be curious to see a a video showing the difference in stopping of a two wheel coast and a two wheel brake.
    agfa
    edited 2010-09-07 17:57
    agfa: I'm on it like "Stink on a Monkey"!
    Demonstrating coast vs brake is one of the reasons I decided to leave the coast option in, even at the expense of one i/o pin. Most people don't understand how important braking is.
    The other reason is, it was much easier and faster to implement!
    Will advise progress. I think I can port my Retrobot Pathfinder software over to Scribbler in one good evening. "And I woulda got away with it too, if it weren't fer these dang kids"!
    One post, two classic TV references: Seinfeld and Scooby Doo.
    edited 2010-09-07 17:59
    Nice work! The ability to halt a wheel is really important for accurate odometry and was one reason I was less than satisfied with my Scribbler mods.
    Stopping is one area where bots using servos have an advantage over Scribbler. When you pulsout a stop pulse you get that same quick stop which prevents over steering and allows for accurate turns.
    But Scribbler's motor controller means you don't need to tend the motor which has other advantages. So this mod allows for both advantages.
    edited 2010-09-07 18:24
    @Martin: You and I are in sync. I put encoders on my Scribbler, and they made it better, but not perfect. I'm sure you saw my square video at http://www.youtube.com/watch?v=5r2En4hLUBI The asymmetrical coasting was quite maddening. I haven't seen two motors yet that will coast identically...
    I know the S2 will be a big improvement over the original Scribbler, but this mod might be helpful (or necessary) to get useful dead reckoning out of that platform, too. I mean, 480 PPR is impressive, but that microscopic knowledge without fine motor control is not bringing much to the party.
    While I'm on a rant, it appears that the motors & mechanicals of the S2 are pretty similar to the S1. There is room for improvement in the bushings and wheel couplings to eliminate backlash and better support the wheels, especially once we start adding arms & weight to the basic chassis.
    That said, I can't wait to start hacking the new S2!
    edited 2010-09-07 19:12
    @erco, I was aware of this, but thought I didn't really understand your initial question. There is more good info in Writing Programs for the Scribbler Robot - http://www.parallax.com/Portals/0/Downloads/docs/prod/robo/scribbler/SPPG-WritingPrograms-v1.2.pdf
    Edit -Great video and use of ancient quotations...you are truly a dad now!
    edited 2010-09-07 19:36
    A total guess is that the PCM is used as the input to the motor controller while PWM is used by the controller on the motor itself. This is because PWM is a really effective way to vary the total amount of power delivered with just a binary output.
    Also, I recently found out that technically servos use pulse position modulation (PPM) which is similar, but not quite the same as PWM. I made this discovery because that other brand of microcontroller has dedicated PWM pins, but can do PPM on any pin.
    edited 2010-09-08 22:16
    The Scribbler's motor drivers have a VERY slow response compared to my relay-fluttering Retrobot, which executed high & low commands almost instantly in comparison. Each of Scribbler's speed-setting pulsout command takes 1-3 ms plus overhead, plus some undocumented delay to take effect, for TWO motors. That makes real-time PID BS2-speed control to sync two motors for straight line operation a real challenge to monitor and control both motors simultaneously.
    So far, my best results have been to "set & forget" one motor at an intermediate speed, and switch the other motor into one of three states: faster, slower, or equal (open loop) speed. This is done by counting and comparing both wheel encoder pulses and knowing when the controlled wheel is ahead of, behind, or synced with the other mid-speed wheel. Using this technique, my bot is driving perfectly straight and stopping at exact, repeatable distances.
    The dynamic braking relay activates instantly and stops the robot very quickly, as my previous video shows. This eliminates delays and coasting inaccuracies using the motor controllers to stop the bot. All my initial tests using one-wheel control and braking are very encouraging, even using one main drive speed without any ramping. Even with my higher ratio gearmotors with more torque, there is little chance of skidding the tires during acceleration or deceleration.
    Long story short, I'm confident that I can modify my Pathfinder software to work properly, although it needs more tweaking than I originally thought. Will advise.
    edited 2010-09-09 04:46
    Have you considered trying a different motor controller to overcome the "speed command" delays? I've used the Pololu micro dual serial motor controller, I think it works quite well. I guess if you keep hacking your scribbler it won't be a scribbler anymore.
    When I tried PID with a BS2, doing nothing but controlling the motor, it struggled just to keep up with one motor using a 34 pulse per rev encoder. That was the point I decided to try the propeller. It sure is nice, I set up one cog take care of encoder feedback, one to create PWM, and another coordinating the two.
    I'm confident you can still rise to the challange of outdoing the S2. I know you'll keep us posted. Keep it up! I do enjoy reading your posts.
    agfa
    edited 2010-09-10 14:21
    One of my old Scribbler tricks might help me out with these slow motor controllers. Normally to stop both motors, I'd use this straightforward code:
    PULSOUT 12,2000' 2000 uS pulse stops right motor
    PULSOUT 13,2000' 2000 uS pulse stops left motor
    This has 2 problems. Mainly, it takes over 4 ms to execute this code; sending two 2 ms pulses plus overhead. That's a long time to ingnore my wheel encoders, I could miss a pulse and ruin my odometry efforts. Also, the wheels may start slightly out of sync since the commands are at least 2 ms apart. Now examine this code, which solves both problems:
    HIGH 12:HIGH 13
    PULSOUT 9,1730' 1700 fwd 1760 rvs
    LOW 12:LOW 13
    High & Low comands execute very quickly compared to a Pulsout. This sends nearly synchronous Pulses to Pins 12 and 13. First, both pins go high, I send a calibrated PULSOUT to an unused pin, then drive both motor controller pins low. I experimentally determined the PULSOUT value 1730 which stops both wheels, equivalent to two seperate 2000 PULSOUTs. 1730 is right between values 1700 and 1760, which I found barely began to turn the wheels in opposite directions. This new code executes in half the time (just one pulsout) and syncs the wheels better.
    Using similar chicanery, I think I'll be able to speed up all motor commands to regain active control of both motors instead of fixing one and controlling the other, per my previous post.
    edited 2010-09-10 15:12
    Neat stuff, erco! My scribbler is feeling mighty lonely lately, and you are inspiring me to dig into it.
    And I gotta say, I really like your robot's girlfriend. She is a cutey, but unless mr big bot is being chivalrous and carrying her over a very big mud puddle, she may have to cut back on the cosmos!
    edited 2010-09-13 10:32
    I spent some time eliminating mechanical backlash in the gearmotors & wheels, which made a huge improvement in accuracy & repeatability. Give your Scribbler's wheels a light tug and you'll see there is a lot of play in most directions. That needs to go in order to have any shot at dead reckoning. S2 may need similar attention. I'm hoping Parallax went with the 220:1 gear reduction on S2, which is what I have on my S1 now. Big improvement in all regards except the wheel stall sensor. Now I have more than enough torque to spin my wheels when the bot hits something, but that's likely to change one I add some weight.
    The arm/claw and death ray should add half a pound, and I can use that traction. :)
    But truthfully, bump switches would be more useful than the stall sensor, which may go. Another thing on my "to do" list.
    edited 2010-09-13 20:08
    Erco,
    I think you'll be much happier with the stall sensor on the S2. It's basically an encoder on the idler wheel.
    @Phil,
    I knew I read something about that. This is what it says on the list of S2 features - "Improved stall sensor on rear wheel." Thanks for the confirmation that this is one of the improvements.
