Flat Lithium Battery Pack DoD — Parallax Forums
ercoerco Posts: 20,263
edited 2010-09-17 09:28 in General Discussion
Interesting form factor on this 5.3V, 2000mAh USB-charged battery pack, might be right for some projects. Ebay Deal of the Day at $30:
http://cgi.ebay.com/Mango-Energy-Chargecard-Travel-Battery-Pack/360293430045?_trksid=p1468660.m2000037
Could even BE the chassis for a small robot!
specs: http://www.mangoenergy.com/PDF/ChargeCardSalesSheet.pdf
500 x 500 - 67K
    edited 2010-09-03 16:54
    These are real cool to have One
    Radio Shack had some that they discounted they work real good for a Basic Stamp Power Supply I got them for $15.00
    and $5.00 for the smaller ones
    I bought about 15 of the smaller one
    Not the same company but they look much the same
    Each of them have 2 @ 800 milliamp Flat Lithium Batteries in them
    and a power switch with a blue LED that come on when you hit the power switch
    Note that when the LED is not on the power coming out is only battery voltage not 5.00 volts
    5.00 volt is when the blue led is on
    they also had a smaller one made by the same company that is only 500 milliamp
    and has only one battery it alway has 5.00 volts on the power cord unless the battery voltage is less than 2.7 volts
    204 x 148 - 19K
    204 x 148 - 25K
    edited 2010-09-03 22:39
    I have started using camera batteries that
    I buy on ebay to power projects. It's a great
    power option.
    edited 2010-09-05 10:37
    Holly
    I have done what you are talk about as well they do work very well
  • Buck RogersBuck Rogers Posts: 2,215
    edited 2010-09-05 19:49
    power option.
    Hello!
    Camera batteries, HollyM? Please explain. I've got a respectable collection of those that were designed for Polaroid, those Polapulse ones.
    I never thought of using them with the Basic Stamp.
    (Nice avatar. Oh and are you related to a chap named Minkowski, was a fantastic astronomer, worked in California with CalTech there.)
    edited 2010-09-07 07:33
    If you have the 8 volt battery pack then all you need in most case is a five volt switch power supply
    One note make sure that it has the voltage protection board in the battery pack that you want to use
    What you can do is take a volt meter and check the battery voltage and if it read a voltage
    One cell would be any where from 2.7 to 4.20 volts
    Two cells would be any where from 5.4 to 8.40 volts
    If it dose not read a voltage then charge battery with a 100 milliamp charger @ 5 volt would work for one cell battery
    and watch battery voltage to see if it stop charging when it reaches 4.20 volts for one cell or 8.40 volts for two cell
    One note DO NOT LET BATTERY VOLTAGE TO GET HIGHER THAN THAT because the battery will start to over heat Also DO NOT USE these battery with out the voltage protection board
    If you get any voltage lower than or while you are charging the battery voltage is over then it dose not voltage protection board
    If your reading is in that range here is a test to see if it has a voltage protection board in it with out taking the battery pack apart put a 100 milliamp load on the battery pack and watch the battery voltage if it drop below 2 volts or 4 volts then it dose not have a voltage protection board
    Buck Rogers
    If you need a voltage protection board for a 8 volt battery pack send me an Email I can send you one if you need one
    I only have ONE to give out in the subject put Need a Voltage Protection Board
    edited 2010-09-07 08:00
    Please check first with a volt meter to see if it is in this range
    Is this what you have see below in Attached Thumbnails
    This should have a Voltage Protection Board in how ever you can NOT put these board in series to make 8 volts you have to remove the Voltage Protection Board for 4.00 volts and change it to a 8.00 volt one with two battery
    300 x 300 - 13K
  • sylvie369sylvie369 Posts: 1,622
    Just a follow-up on the original product that Erco showed us: mine has arrived, and works beautifully on both my cell phone and my iPod Touch. It'll be especially convenient to have an external battery for my cell phone, which is one of the (many) battery hogs out there.
