Using Opto22 Modules with a Propeller — Parallax Forums
Al BoothAl Booth Posts: 137
edited 2010-09-02 20:18 in Propeller 1
Has anyone used Opto22 Modules with a Propeller? I need to, and plan to drive the output module with a 2N2222 from a Propeller pin. And hope to directly connect the input module to another pin. I am a little concerned that using 3.3 volts on the input module might be too low. Any comments, or suggestions?
Al
  • JonnyMacJonnyMac Posts: 9,462
    edited 2010-09-02 12:22
    Some of those modules are rated that low, but for about a quarter you can add a resistor (limiter into base) and transistor to switch 5v or higher into the module. Using an NPN is easiest, I think, so you'd switch the negative side of the control input with the collector of the transistor.
    If you're going to be controlling more than a few of these relays you can plunk a ULN2x03 in between the Propeller and the relays.
  • Al BoothAl Booth Posts: 137
    edited 2010-09-02 12:35
    Thanks for the reply, Jon. I do have the 5 volt versions of the modules (IDC5 and ODC5). Since I only have 1 of each in my circuit, I'll stay with the transistor driver. I was aware of the ULN2x03 line of parts, but it would be overkill since I only need 1 or 2 drivers.
    edited 2010-09-02 16:40
    The specs say the 5V modules switch on at 2.8V and off below 1V. I would just drive them straight fromthe prop pin. First google hit: http://tomscarff.110mb.com/midi_12_out_4_in/OPTO22_Std_Dig_DC_Outputs_data_sheet.pdf
    For inputs, if you have 5V available just feed the opto 5V and run the input output line to the prop pin thru a 10k resistor.
    Yes, if that PDF is it, there's a pic of the equiv ckts and the input is just an LED and a resistor, in series (refer esp. R_sub_C), > 2.5V, direct driveable (within reason.)
    Post Edit -- Dispel all doubt, get the ammeter out.
