Serial I2C LCD 2X16 with backlight USD15 each
william chan
Serial I2C LCD 2X16 with backlight only USD15 each! excluding shipping.
Can ship by Regular Airmail to anywhere in the world. USD10 per shipment for small quantities.
FEATURES:
Comes fully assembled and tested with 1 year warranty.
Works well with Propeller chip. Does not use up an extra cog.
You can choose direct solder to LCD or use header connectors. (See third picture)
Fast optimized SPIN Object is provided with perceived update speed faster than 9600 baud at 80Mhz.
Command for "Hard Reset" which actually powers down the LCD module and powers up again.
Can share pins with the boot EEPROM.
Propeller can run at any speed from 5Mhz to 96Mhz.
Pre-adjusted contrast. No need further adjustments.
Low profile with mostly SMD components.
Very low power, 2mA active. Can be used in battery applications.
Soldered with lead free solder.
Stable and matured, proven in several commercial products.
SPECS:
Power Supply : DC 5v
Current Consumption : 2mA active with backlight off. 90 mA with backlight on.
Serial Protocol : I2C
NOTES:
1. Requires pull up resistor 5k-10k value on SDA pin.
2. Series resistor is built-in allowing direct connection to any Propeller IO pin.
3. FlexiStrip 0.1" spacing ribbon cable is provided. Can solder or plug in direct to "turn-pin" connector.
FEATURES:
SPECS:
NOTES:
INTERFACE:
init
reset
onlight
offlight
clear
sleep
cursor_off
cursor_on
str(stringptr)
clrline1
clrline2
line1
line2
num00(value)
dec(value)
hex(value, digits)
char(byte)
