2-layer PCB ground plane advice
Hi-
I'm rather confused on the conventions for ground planes on 2-layer PCB's. I seem to have seen commercial ones that have one on the bottom, and some that don't.
The reason I'm asking is that I've designed a few boards that have mostly been so small / full of traces that there wasn't much leftover space, but this time we've got some that have lots of empty space on them. Is it good practice to cover the bottom and /or top side with a ground plane, and what's a good explanation for why or why not?
Thanks!
Rafael
Thanks!
Rafael
When you send power down a trace on the top the return current will follow the trace on the back side of the board back as much as possible. For this reason if you do run traces on the ground plane side you need to run the trace in a way to minimize how far out of the way the current has to go or create alternate short paths it can use.
Rafael
As phil said traces on pour are almost unavoidable. there are a few things you can do to reduce the effect of them.
1) Keep traces on the bottom short and do not cross high frequency signal traces when ever possible.
2) use a coper pore on both sides of the pcb and use vias to allow return signals to flow for short periods on same side as trace. This can cause ground loops if you are not careful.
3) use a positive coper pour on side with all traces and use bypass caps to allow return current to travel through positive pour. This increase part count and is strange to understand how it works.
4) Go to a 4 layer board and use 2 layers just for positive and ground. There are different pools of thought on which layers are best to use for what:
Some say:
1) low frequency & secondary traces and parts.
2) positive plane
3) ground plane
4) high frequency & primary traces
I prefer
1) positive plane and parts
2) high frequency and secondary traces
3) ground plane
4) low frequency and primary traces
The advantage of the first is you get a slight decoupling effect between the power planes and the planes will be completely uninterrupted. the disadvantage is the planes are not shielded at all, and traces on the top are far away from the ground plane.
The advantage of my way is if you route your high frequency traces where there is full copper on the top they are shielded. Also both layers 2 & 4 have great coupling to ground. The disadvantages are boards can be easily rendered useless during rework by pads lifting, and positive plane gets interrupted by parts. It is not a mistake that high frequency and secondary traces are together on my suggestion and high frequency and primary are together in the first option.
It seems that most of the EMI energy is created in the oscillator for the microcontroller. Other signals tend to have less driving force and be less frequent and/or irregular.
So unless you are doing something with ADC or op-amps, the circuit board is likely to not have problems. But don't forget the de-coupling capacitors at every IC.
See the middle pictures on http://javalins.wordpress.com/projects/databox/
Seems to work really, really well. Version 1 of the board with a solid gnd layer, version 2 with a split gnd plane results in a faster and better gps lock
James
The reality is that the average hobbyist cannot afford the testing to get a board properly certified as good for EMC requirements. It takes having a shielded room that can measure exactly what is occuring.
The SXes really can go up to 80Mhz at 5 volts, but beyond that it becomes difficult to prevent without spending big bucks on testing. With the BasicStamp, the SXes, and the Propeller, there is usually no issue unless one is seriously overclocking.
It doesn't hurt to try to build a board to be reasonably protected, but it is all guess wirk when done without testing. And, the reason for boards with many internal layers is to overcome what a two-layer board cannot really accomplish. Still, it is good to discuss how to get started with it as some people here may eventually end up in engineering and want to get started with thinking about it.
