[resolved][puzzle] PASM beginners only
This code fragment was taken from the thread [post=935692]From SPIN to PASM - Code Documentation Style - Just curious[/post].
Make it smaller! Bonus points for keeping character alive.
'if (character >= '0' && character <= '9') cmp character, #[COLOR="Red"]$30[/COLOR] wc if_c jmp #fail cmp character, #[COLOR="Red"]$39[/COLOR] wc,wz if_nc_and_nz jmp #fail pass {do stuff here if condition is true} fail {continue here if the condition is true or false}
At least that is all my sleepy head can come up with
Nice try, pass range is $30..$39, fail is everything else. In your example $30 would actually fail.
...is if you press one of the keys...
0, 1, 2, 3, 4, 5, 6, 7, 8, or 9
on the keyboard (ASCII $30 to $39)...
Then (do something) - [Pass]
Otherwise (do something else) - [Fail]
Edit: That is hexadecimal (hex 30 to hex 39).
A version just using jump instructions:
I thought this was for PASM beginners....... :smilewinkgrin:
Totally lost me with that last one.
How about adding some comments for PASM beginners like me
Coley
Apologies, I just thought I point out what's possible to get the thinking-outside-the-box going. Comments coming up:
Step #1: Take the value and subtract $30 from it. That'll give you a value from $0 to $9 if it is within range. If it is less than 30, just ignore it, it'll roll over to a higher value, which is ok. If it is higher, still ok.
Step #2: Compare that value to see if it is greater than 9. (CMP char,$9 WC)
Step #3: If it is conditional jump to "fail" based on the C flag (IF_A)
Otherwise it will simply fall through to "pass".
Off the top of my head, the code would look something like this:
Bill
In your original code, the entry point was not made clear. If the Z flag was set, using IF_A would not work in your code below.
Thanks for the exercise! I was not aware of the IF_A. (IF_NC_AND_NZ)
Terry
That's fine, I'll donate three # characters and a wz for this first working solution
Bill
Also what would happen if a Carriage Return ($0D) were assigned to char. I know you would get an underflow, because we are dealing with unsigned values. There would be no easy way to restore the original value of char, would there?
How about: -Phil
Beau,
Your solution looks vaguely familar! :-)
Bill
It is! If anyone has any questions about the above, this is the time to ask.
Hint: *Any* key on the keyboard can be pressed and the hex "ASCII" value for that would be "character". So character could be...
A
a
7
W
0
etc.
Only if it is: 0, 1, 2, 3, 4, 5, 6, 7, 8, or 9 would it pass.
The hex ASCII numbers for these would be...
$30, $31, $32, $33, $34, $35, $36, $37, $38, or $39
ASCII tables many times show numbers for decimal, hex, and octal. Hex is typically used in my experience. Here is an ASCII table...
BTW, Beau, re-using Bill's entry wasn't very nice
A Both different and not the same as the one I came up with (we all used the same basic idea though).
B ... and doesn't involve undocumented features.
"BTW, Beau, re-using Bill's entry wasn't very nice"
...Touche, but I could say the same thing about you borrowing my original code ... I won't hold a grudge if you don't ... all fun anyway, lets exercise the mind!
Ah, you got me there, at least I was considering asking for permission ...
This one passes for chr > $30 ... not exactly what we're after
I actually ran this code on the demoboard and that's what I got. If I change if_b to its opposite if_ae the test passes for chr > $39. Third time lucky?
Forget paired cmp's, they don't match.
If you refer to [post=935826]posting 5[/post], well, I thought it was obvious that this isn't a beginners solution. Do I have to spell out everything?
Any nop that shows up in the list below means pass.
