SSR Operation Question
Hello All,
I am trying to design something to operate as a switch on an electric skeet thrower using a BS2 pin as a control. The problem I have is there are many varieties of these machines and some are AC operated, while others are DC operated with car batteries. My control circuitry will be battery powered seperately (using AA batteries).
My original thought was to use a mechanical relay big enough to handle the voltage and current of either the AC or DC case. However, the switch will need to stay closed for indefinite periods and I don't want to draw the coil current from the AA batteries for a long time to avoid draining the batteries.
My next thought was that this sounds like a job for an SSR. This would have the advantage of low current requirements to activate the relay. However, I don't know enough about them. Will an SSR designed for AC carry a DC signal as well? It seems logical to me that it would, but I'm hoping someone here can confirm or deny whether this is true. I also read something that seemed to imply that conduction of an SSR is related to the voltage across the two load terminals. This is creating much confusion for me.
Are there other considerations I haven't thought of? I see many types of SSRs available and I'm not sure which to choose for this application.
Thanks for your help.
Greg
Greg
and unlike Mech Relays the are Polarty sesitive to the output .
