Make a Fake LED
[FONT="]There are 2 methods below for blinking two real LEDs at different rates. I want to change real LEDs to fake LEDs where nothing exists, but the identical timing is maintained. It appears, to accomplish this, the outa statement needs a substitute statement with exactly the same timing. If it's true that statements take 4 cycles, then any other Spin statement could serve as a replacement. Is this true, and which statement could be substituted? Thanks in advance. Humanoido
[/FONT][FONT="]PRI task0 ' Private Method - Task 0
case state0 ' Flash LED1 every second
OFF:
if (ms // 500) == 0
outa |= %01 ' Pin 0 on Main Header
state0 := ON
ON:
if (ms // 500) == 0
outa ^= %01 ' Pin 0 on Main Header
state0 := OFF
PRI task1 ' Private Method - Task 1
case state1 ' Flash LED2 twice every second
OFF:
if (ms // 250) == 0
outa |= %10 ' Pin 1 on Main Header
state1 := ON
ON:
if (ms // 250) == 0
outa ^= %10 ' Pin 1 on Main Header
state1 := OFF
[/FONT][FONT="]'
[/FONT]
OFF:
if (ms // 500) == 0
state0 := ON
ON:
if (ms // 500) == 0
state0 := OFF
OFF:
if (ms // 250) == 0
state1 := ON
ON:
if (ms // 250) == 0
state1 := OFF
[/FONT][FONT="]'
[/FONT]
[/FONT]
waitcnt(value) = Wait until the system counter = value (page 219 in the manual)
waitcnt(clkfreq + cnt)
simply waits for exactly 1S, regardless of the system clock value
waitcnt(clkfreq / 2 + cnt)
takes current clock frequency, divides it by half then waits until system counter matches the calculated clock ticks of 1/2 clkfreq plus current system counter reg value (0.5 sconds). Also variables can be passed to the equation as well, ie;
waitcnt(clkfreq / x * a + cnt)
waitcnt(clkfreq / 1000 * 39 + cnt)
divide current system clkfreq reg value by 1mS, then multiply the 1mS by 39 to get a binary value for 39mS based on the current clkfreq reg value, then adds that to the system counter value and then proceeds to wait for the 39mS you specified.
Traps:
*always specify it as (offset + cnt) not (cnt + offset), the latter does the math (optional) and then activates the wait hardware in the cog.
*in spin value absolute minimum = 381, the overhead number of clocks it takes the interpreter to evaluate the expression, equation or not.
Tip:
*pre calculating those values used often and refrencing them as constants or variables for use in your entire program code or just in a pri block
**Also note that SPIN commands/programs are many times slower in execution than PASM equivalents and most SPIN commands take many more than 4 clocks to complete, the waitcnt command for example takes at least 381 clocks. Using the counter A/B modules within the cog, you can produce basic square waves/frequencies up to 128MHz using PLL and/or NCO modes but the spin program runs 1,000's of times slower than that. You can even use the special waitvid command to pass the video hardware -after setting the appropriate bits in the vconfig reg- bit patterns to shift out over 4 to 8 i/o such as how the TV and VGA drivers accomplish output.
If your looking to toggle/pulse an output with optional output disable you can simply do:
