Dollar Servos
A while ago, I was amazed to find small 9g servos for ~$2.40 each in batches of 12. I ordered a bunch from HK, and they work fine. Not super-high quality, and they cannot be made into continuous servos since they only have an output gear sector (half a gear). But to play around with and think about making a gazillion-servo walker or such, they are well worth it.
Well, I just found two servos for $2.33 (free shipping from HK) at http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=110579827241 and ordered 8 more. Let's see, a cheeseburger, or a servo? I have to wonder if they can ever be cheaper than this, or will this seller come to his senses and raise his price?
Similar servos can be bought in the US from http://www.hobbypartz.com/topromisesg9.html for $2.77.
The left is the final prototype(hextronik servos) and the right is the orginal(hitec HS-55's). It runs on a Prop and it has an IK engine as well as several different walking gaits. I plan to start my own thread(finishing up some videos) but just saw this and thought I'd show what I used these cheap servos.
Per my original post, "will this seller come to his senses and raise his price"?
Apparently so.
Humanoido
Looks great, what did you use to machine your parts? I look forward to seeing your videos!
Videos will be up tommorrow.
I saw the video of your hex with the prop. Nice work. You posted a comment on my youtube account as well. (QuantumRoboticsInc's channel)
The little blue hex was the first proto type. Since then I went from foward kinematics to inverse kinematics.
Your board looks like my first prototype and should run the code no problem. I will make the code public to as it uses objects posted here.
Here are those little servos at work. For the money they are tough little guys.
http://www.youtube.com/watch?v=eddcCu5X9iM&feature=player_embedded
Older vid using Foward Kinematics. 1st prototype.
http://www.youtube.com/watch?v=wK5A97Wyqtc&feature=fvwk
I will be making a dedicated thread on my large hex and will go into details and post code. I finally got the code cleaned up.
You can take a look at the most recent video as well its under my profile on youtube.
Nice to hear a glowing review and recommendation for $3 servos. Do you have a link to your Hextronic servo source?
http://hobbycity.com/hobbyking/store/uh_viewItem.asp?idProduct=662 is the link. I usually stock up on things when I place an order so the shipping charge dosent sting that much.
