Hitachi H48C Tri-Axis Accelerometer with cable
I'm trying to use an Hitachi Accelerometer with a 3 ft cable with a Propeller proto board. When I'm using the accelerometer with a breadboad (without the 3 ft cable), I have a good accelerometer signal, but as soon as I use it with the 3 ft cable, I get some weird signal.
I guess that the problem is my cable, but when i'm using the same 3 ft cable with the MMA7455 accelerometer I don't have any problem..
If someone have an idea.. thanks!
XYZDataHitachi[0] := Adc.getval(0)
XYZDataHitachi[1] := Adc.getval(1)
XYZDataHitachi[2] := Adc.getval(2)
'Send X data in 2 bytes
DataOut := XYZDataHitachi[0]
Debug.tx(DataOut_High)
Debug.tx(DataOut_Low)
'Send Y data in 2 bytes
DataOut := XYZDataHitachi[1]
'Send Z data in 2 bytes
DataOut := XYZDataHitachi[2]
I'm 100% sure that my code is ok because it's working when i'm using it with the accelerometer on a breadboard.
And by a weird signal, I mean there's some kind of noise and the signal is not what it should be. I can show you a graph of both signals if you want.
For the connections, I'm using wire wrapping wire (awg 30).. Can it be the source of my problem?
