Need Specialty Toggle Switch...dont even know if this has a name
Hi all-
I'm looking for a special switch, I don't know what you call it and not even whether it exists.
What we need is a plain toggle switch (on-off) that can ALSO be sprung back to the off position with an electrical signal. Sort of like a latching relay, but one that you can move manually as well.
Does this exist?
[Btw, first time logging in to the new forum, noticed a couple things:
"Welcome, FlyingFishFinger.
You last visited: 12-31-1969 at 11:00 PM"
Also, neither my avatar nor my bio nor my PM inbox got ported. Is that correct?]
Rafael
Does this exist?
Rafael
R
Though most are of industrial size.
How about some form of normal switch (spring return to off) driving a relay and having the micro de-energise the relay at the correct time?
I'll look into those breakers, they're of the right principle. Anything smaller than breakers exist? We're only switching 12V at fractions of an amp...
Thanks though!
Alt: or a spring return to center-off SPDT toggle switch that energizes and de-energizes a latching relay, which is also controlled by an external circuit.
Hence the spring return to off (sometimes also called a momentary switch).
But the obvious solution is to use something else to indicate off - such as an LED. And then use a relay that latches the circuit in the on position. By having an SCR crowbar the relay to off, you have a trigger than a microcontroller can pull.
I doubt anyone is manufacturing what you want. Why so? The switch makers probably have to make 10,000 units before they are cheap enough for demand to possibly kick in.
I also suspect that abandoning the toggle for a push button might be a better choice. You might find some sort of push button that is release to an off position by a solenoid. Mechanically, it is easer to have a push button revert to an off position than a toggle.
