Propeller BackPack Firmware
Tumbler
I want to reinstall the original BP firmware (no overlay) without success.
To be honnest, i don't wich library i have to upload. The monitor or the terminal.
I tried both with the BP loader (using a BS2) and tried the 'Load Ram' and the 'Load Rom' button.
And since i have tried all binaries i found, i don't know what is left or right anymore.
3 ways to upload new firmware, the propplug, the Propeller Backpack Loader program with a pp and the Propeller Backpack Loader program with any member of the BASIC Stamp 2 family (no
Prop Plug required).
And now you are telling me that i need a pp.
See the bottom of page 14 of the Propeller Backpack documentation for a description of how to restore the loader using a PropPlug or equivalent. There are instructions on the top of page 15 for restoring the firmware using a Stamp and the Backpack's loader if the loader is intact.
Thx Mike
If you've never programmed your Backpack with a Prop Plug, there remains a good chance that the monitor/loader is still loaded in EEPROM. However, some user programs do not recognize the serial BREAK condition required to to reset the Backpack and alert the monitor that a program is to be uploaded. In those cases, the LoadBP program will display a message for you to press the reset button to commence the loading process. Is it possible that you simply missed seeing this message? Also double check your connections to the BASIC Stamp before retrying.
After resetting the bp, i get another message: no basic stamp found.
If no: Double check your cable and, if you're using one, your RS232 converter.
If yes: Are you using Windows 7 by any chance?
The BP loader first starts with donwloading. seeing block waves in the 'debug window', after a few seconds it asks to press the reset button.
Then is says basic stamp not found.
Using w2K
I had no probs when i had download the tv overlay into the bp.
Having a ntsc/pal tv. I wanted to use the bp to monitor some date while i was watching tv. But my digital tv decoder only had pal output. So it won't work (ok, my fault. I had to look better to the output signal of the decoder)
If i'm correct i have to download the monitor firmware to the eeprom using the 'load rom' button and the terminal firmware with the 'load ram' button?
1. You only need the monitor program in there if you intend to load programs via the three-pin header using a BASIC Stamp. If that's the only way you've ever loaded programs, it's probably still there and doesn't need to be reloaded.
2. Both thte monitor program (if you use it) and the terminal program have to be loaded into EEPROM, else they will disappear when power is removed. You can either overwrite the monitor program with the terminal program via a Prop Plug, or you can upload it with LoadBP using the monitor program. Either way, it will start on power up.
But only the tv terminal (no overlay) firmware is working here.
and i seems that the firmware, on the product page is different from the previous installed firmware. Is this a thought?
